Old 04-12-2021, 03:08 PM
330Jock 330Jock is offline
Default Instrument Panel on 7A
Ok, this is gonna sound dumb, but I'm gonna do it anyway!
When I look at photos of all those great panels out there, they look like they are level, or square to the eye. I am just putting my upper fuselage forward section together. Ribs, sub panels, skin, instrument panel, and when you get everything clekoed together the panel is canted back oh 7 to 10 degrees or so. In other words the bottom of the panel is closer to you than the top of the panel. As I look at the rivet lines, angle of the glareshield, angle of the sub panels, they are all angled the same amount, including the upper firewall. Is this correct? Just wanted some confirmation that I wasn't nuts!
Bill Stockburger
RV-7A Slider
IO-360 M1B Thunderbolt delivered, Hartzell 74" Composite delivered.
Empennage Finished (except fiberglass), Wings Finished (except FG), Fuselage in progress. Restarted project 6/15/2020
N776DD (Reserved)
2021 Dues Paid
The test of a first-rate intelligence is the ability to hold two opposed ideas in the mind at the same time, and still retain the ability to function. - F. Scott Fitzgerald
Old 04-12-2021, 03:30 PM
rapid_ascent rapid_ascent is offline
Yes the panel and the upper firewall are angled forward very slightly.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-12-2021, 04:45 PM
Ralph Inkster Ralph Inkster is offline
Panel should be canted forward 8 degrees compared to the side longeron (after the bend at the spar bulkhead).
Back in the days of vacuum AI instruments, you had to specify the 8 deg offset.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 04-12-2021, 04:53 PM
Thanks guys for confirming I am not nuts! I appreciate it.
Bill Stockburger
RV-7A Slider
N776DD (Reserved)
2021 Dues Paid
Old 04-12-2021, 08:10 PM
agent4573 agent4573 is offline
This was taken with the square on the backside of the panel. If you put the square on the longeron it's even a more pronounced angle.
www.rv7build.com
Old 04-13-2021, 08:51 AM
Thanks for the picture Paul!
One more question now that I understand the info you guys provided. When installing the F721 C&D angles that hold the bottom of the panel, did you mark them while the skin is on, and then actually install them with the skin off. Was thinking how hard it would be to get under there with the skin on.
Bill Stockburger
RV-7A Slider
N776DD (Reserved)
2021 Dues Paid
Old 04-13-2021, 09:22 AM
PilotjohnS PilotjohnS is offline
I installed after the side skin was on. I am not sure how one would do this with the side skin off, since so many things have to line up to make the position accurate. The rivets are accessible from the open front end. (Assemble panel with brackets; drill brackets, remove panel, rivet brackets; easy peasey)
John S
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 85% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 04-13-2021, 10:45 AM
Thanks John.
Bill Stockburger
RV-7A Slider
N776DD (Reserved)
2021 Dues Paid
Old 04-13-2021, 02:57 PM
rzbill's Avatar
rzbill rzbill is offline
I remember those.
When jigging it together, I think I never used more clamps in a smaller volume anywhere else on the plane.
Bill Pendergrass
ME/AE '82
Old 04-14-2021, 11:00 AM
I marked and drilled everything with the top skin on, then removed the skin. It wasn't removed for the sole purpose of putting these rivets in, I just wasn't ready to full install it yet. I couldn't figure out how to get a squeezer in there, so you have to buck most of these rivets, and you should have the space to do that with or without the skin in the way. It's a lot easier without it though. Also, the center rivet in the bracket is impossible to get the gun fully seated if you've already installed the nut plate. I would suggest drilling everything out and prepping everything, then install the brackets onto airplane, then install the nut plates onto the brackets. My 2 center rivets have smiley faces from a slightly offset rivet gun.
www.rv7build.com
