Old 06-27-2022, 09:36 PM
cajunwings cajunwings is online now
Default Flap Switch Location
Mine is on the panel to the right and above the engine controls because thatís where it is on most of the other planes I fly.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 06-27-2022, 09:48 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
RV-6, second iteration on the panel - the first was standard 6-pack so I rearranged things some including flap switch when I went to a new panel with glass.
From that experience, I chose above / slightly left of the throttle for the flap switch, and for me it's perfect as I can operate it with my thumb while my hand is on the throttle.
As an aside, I always liked manual flaps in Cessnas, and might have done that in my -6. But while I was building I was fortunate enough to get 50 or so hrs in a manual flaps RV-6 and that convinced me that in SBS RVs, the geometry of the manual flap handle is far less than ideal. So that's why I chose electric flaps in the -6. Dunno if manual flaps are even an option in the newer models? But in case so, food for thought.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated January 2022
Old 06-28-2022, 05:36 PM
iamtheari iamtheari is offline
In my RV-14, I put a flaps switch on the panel just above the Steinair throttle bracket. With over 100 hours flying with it, I like it there and wouldn't move it.
Side note for the over-thinkers: I put some effort into designing an "alternate flaps" system that would let me raise and lower the flaps in the even the VP-X Pro fails. I ended up not doing the alternate flaps because no-flaps landings are a non-event in the RV-14. I did put in alternate trim that allows me to send power from the IBBS backup battery directly to the pitch trim.
Old 06-28-2022, 06:47 PM
Desert Rat Desert Rat is offline
In the same general location as a Cessna. That's a muscle memory I don't see a need to unlearn.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 06-28-2022, 08:26 PM
plehrke's Avatar
plehrke plehrke is offline
Originally Posted by bjdecker View Post
Not a -14, but in both of my -7's I placed it just above and to the left of the throttle.
I'm just not a fan of "extra" functions on the stick...
My 6A, Exactly the same.
Philip
RV-6A - flying 1000+ hours
Paid dues yearly since 2007
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. óMARK TWAIN
Old 06-28-2022, 10:59 PM
rapid_ascent rapid_ascent is offline
For the Garmin G3x system with a GAD27 you can have two sets of flap switch inputs. I have a panel switch just to the left of the throttle as many others. I also have a flap switch on the pilot stick. I haven't flown with a flap switch on the stick before so I thought this is is a good starting point. If at some point in the future I get used to or decide I like the stick flap switch then I can use that as the primary. I think the flap switch next to the throttle is pretty convenient though so we'll see how it goes.
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
Sensenich Composite 3 Blade Propeller
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 06-29-2022, 12:18 PM
wjb's Avatar
wjb wjb is offline
I have both ... one the stick and one the panel just above and left of the throttle.
I only use the one on the panel. It's very convenient for all operations, especially fast reconfigurations on touch and gos. I'd be happy to dump the flap switch from the grip and never look back.
Bill Bencze
N430WB RV-7 @KHAF, Flying 150+ hrs
VAF 2022 donation happily made
Old 06-29-2022, 12:28 PM
MacCool's Avatar
MacCool MacCool is offline
I don’t use flaps that often but it’s my preference to put the flaps down with the switch I have on the panel. However, I do think it would be nice to be able to command full flap retraction from a button on the stick.
Currently my flap switch is a momentary rocker switch so I have to continually hold it for flaps up or down in the circumstances where I might be using flaps. I don’t mind that for adding flaps but it would be nice on a go-around or touch-and-go to not have to hold the switch continuously to retract them. I’ve had my eye on the flap positioning system from Showplanes, but they tell me I have to use their switch, and I don’t care for it. I’d buy it if I could use my existing switch, or something not quite so….functional…in appearance. This stuff is on my list of things to investigate but I haven’t got that far down that list yet.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 06-29-2022, 01:29 PM
RhinoDrvr RhinoDrvr is offline
Iíve got my flap switch on the panel above the throttle. Itís a gigantic flap shaped switch, so itís easy to access without looking. Iím not a fan of the HOTAS flap functionsÖ
With a center console throttle it would be easy to put a toggle just to the side or behind the throttle control, thatís where the flap were in the jets I flew with console mounted throttles.
Evan Levesque
RV-8 N88MJ (Built by Michael Robbins)
Lemoore, CA
Old 06-29-2022, 07:44 PM
I donít find the geometry to be a problem, and I like the simplicity and fail safe aspect of manual flaps. I can dump the flaps in the blink of an eye on a gusty landing, and Ďglueí the airplane to the runway. I can extend or retract the flaps on preflight, or during maintenance without powering anything up electrically. Iím a fan of manual flaps.
SH
RV6/2001 built 2000/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
