Hi Guys,
Just wanting to know what length you all ended up with your left side stick?
I have a Tosten grip (mounts on end of stick), and after reading all about "leaving stick full length" in other posts, I did that, but it looks way to long. Was that if you used a slide on grip?
Sure looks like I will have to cut the stick down to get the grip at the position it needs to be.
Thanks for the input.
