Old 07-11-2021, 08:45 PM
beauzo beauzo is offline
Default Any RV-14A's near Austin, TX?
This might be a long-shot coming up to OSH...
I'm (still) in the (hair-pulling) process of mission definition/kit down-selection -- very close to pulling the trigger on a 9A. However, there's a creepy, waggish voice instructing me to checkout a 14A before I jump. I would be obliged with an opportunity to get up close to a real 14A near the Austin, TX area. I can fly to you if within reasonable spam-can range of KGTU.
Thank you,
-Beauzo
Old 07-12-2021, 07:19 AM
BOHICA BOHICA is offline
Mine is only at the Empennage assembly point in NE Austin.
Old 07-12-2021, 02:16 PM
Hi BendOver...,
If you're willing, I'd appreciate a run-down of your selection process experience. I've scoured the Internet and forums on the topic, but have only talked to a handful of real folks on the matter.
Are you building at home?
Old 07-13-2021, 09:40 AM
KeithB's Avatar
KeithB KeithB is offline
Iím located at 0TX1 Pecan Plantation in Granbury (SW of Ft Worth) - about an hour flight in the RV. Iíd even be willing to fly down if youíre buying lunch.
(972)735-9136
Warning - I will shamelessly promote the RV 14.
Keith Brown
RV-14A Builder - kit #136 (complete) and #770 (in process)
N314KC - First flight Mar 8, 2017, 24th in the air, >750 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2021
Old 07-13-2021, 10:00 AM
(972)735-9136
I would love to see your 14 as well. I flew the RV-7A at Vans back around the time the 10 came out. Flew in my friends RV-6 some as well. But haven't actually touched a Vans for years. You could solve my withdrawal.
Old 07-13-2021, 10:07 AM
Originally Posted by beauzo View Post
Hi BendOver...,
Selection was based on:
Pro's
RV-14 wider than RV-9.
RV-14 range longer than RV-9
RV-14 cruise speed higher than RV-9.
Con's
RV-14 has a higher fuel burn. But if you run a RV-14 at 55% you beat a RV-9 top speed with up to 135HP engine.
My mission is to fly between Texas and Montana a lot so speed and and comfort (width) is what I went for. My impression is that the RV-14A will be a good cross country flyer with exceptional performance.
Old 07-13-2021, 11:50 AM
Default Group lunch?
(972)735-9136
Keith,
Given both BOHICA's and my interest, and our close proximity, it sounds like we should coordinate a group lunch? The Georgetown area has above-average eating establishments.
BTW, I have a buddy working on his IR that needs a lot of XC time. So, I'm also willing to fly up to Pecan Plantation if you're unable.
In the meantime, I'll take this conversation offline by PM'ing y'all my contact info.
Thank you!
-Beauzo
Old 07-13-2021, 06:41 PM
hawkeyestof's Avatar
hawkeyestof hawkeyestof is offline
Beauzo. Should you want to see build in progress I'm in GTU-engine mounted, panel done ready for gear, exhaust and cowling. She's a joy to build
Jerry Stofer Georgetown,TX
RV-14 engine on - hello baffles
RV-12 N238GS flying
RV-8A N838GS IO-360 C/S WW prop - SOLD
Flew her to Alaska and Caribbean Islands
Wright Bro Master Pilot Awardee
Double VAF combat exclusion -
double contributions made 2012, ......, 2021
Old 07-14-2021, 10:57 AM
I wouldn't mind taking a look as well.
Old 07-15-2021, 10:16 PM
That would be awesome, Jerry. Thank you. PM incomingÖ
