Go Back   VAF Forums > Model Specific > RV-14
Old 08-03-2021, 02:00 PM
ryane67 ryane67 is offline
Default workspace considerations for dimpling skins on the -14
So I'm finalizing my workshop and I was thinking about where I would put the DRDT2 (or c-frame, whichever you prefer) and I realized I didn't know how much space I would need on either side of the dimpling machine because I don't know what the biggest (longest?) skin is that we have to dimple for this plane.
I'm thinking that 3-4ft on either side of the dimpling fixture should be enough, but I want to be sure. If those dimensions don't work then I'll have to keep the dimpling in the "secondary workshop" AKA wife's portion of the garage... and we all know that doesn't always work long term.
can anyone tell me the length of the longest skin we have to dimple for this plane?
Ryan
RV14 tail on order, expecting to begin late 2021.
VAF donation made `21
Old 08-03-2021, 02:23 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Portable
Dimpling is done occasionally only, so rather than a fixed setup, have you considered using a narrow portable stand for the dimpler? That is what I use (for my -6A, which is smaller than a -14), along with two six foot folding tables that get set up either side of the dimpler. It works very well and takes up little space when it's not being used.
(3-4 feet is probably not going to be enough for the wing skins and some of the fuselage skins.)
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 08-03-2021, 02:34 PM
Not a bad idea. I was saying 3-4 feet on both sides, so 8 or so total.
I definitely don't think it'll be a fixture in the workshop, more set up and torn down as needed so your idea is a good one.
Ryan
Old 08-03-2021, 02:57 PM
Ralph Inkster Ralph Inkster is offline
6 or 8 foot table worked for me. I slid the dimpler Lt & Rt down the table as needed so sheet never over hung the table dangerously either end. I also used 2 small plywood platforms (1' x 2' spaced vertically with 2x4s) to keep the sheet horizontal, also slid them around to best stabilize the sheet as needed.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 08-03-2021, 03:06 PM
MED MED is online now
I found a rolling cart to be helpful keeping the long empennage and wing skins from hanging too far unsupported.
MED
140236
N435MD
Miss March 2020
Old 08-03-2021, 03:18 PM
TASEsq TASEsq is offline
If your dimpler is fixed I would think you need 15-16 feet space. A better idea is to just move the dimpler around the table (I screwed it down) and use little tables to hold the skin up. This post shows the dimpling tables - they have carpet on them now.
This blog entry has a pic of one of the longer top skins on the bench being dimpled to give you some idea.
By far the hardest thing to dimple is the horizontal stab skin - I found the best way was to hang it over the edge of the bench so the skin went under the bench - and the male die on the top. This post shows a pic of how I did the HS skins.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 08-04-2021, 03:42 AM
SteveHicks SteveHicks is offline
Default DRDT 2 Mounting
I mounted my DRDT2 between two movable benches, which worked well for me. See this blog post ...
https://vansrv14project.uk/2018/09/0...imple-session/
Steve Hicks
RV14 - building
www.vansrv14project.uk
Old 08-04-2021, 04:35 AM
tyconnell's Avatar
tyconnell tyconnell is offline
Another idea here.
Click image for larger version
Ty Connell
ty.connell@gmail.com
Donated 2021
Old 08-04-2021, 08:06 AM
wirejock's Avatar
wirejock wirejock is offline
Default Bench set up
Mine was like Ty above except...
I use EAA benches. Easy to move them around. The platform and C-frame were not permenant so everythjng could be arranged to fit the job.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 08-04-2021, 08:44 AM
Thanks for all the tips everyone!
Looks like I've got some more ideas to consider placement and surrounding infrastructure.
I might try and create some sort of modular tabletop out of Foamular insulation board that sits ontop of whichever workbench is in use at the time and matches the dimpling level of the DRDT2 so it can be lightweight and easily setup/torn down and stored in relatively small amount of space.
Ryan
