Old 11-24-2020, 04:02 PM
Keldog Keldog is offline
Default Need advice
Strange thing happened twice now when shutting down from a flight. Idle in towards hangar after taxiing at about 2000 rpm's for 2 minutes, idle back to 1800 rpm's before shutdown, then off avionics, off Ignition A, off Ignition B, off master. Instead of immediately coming to a halt as normal, the engine continued to stumble on very roughly. Not sure what to do, I pulled the choke out and it finally rotated to a stop. First time it did it about 3 weeks ago, I thought maybe bad ground on one of the ignitions. So I took off the top cowl, checked all the connections on both modules and followed ground wires to eventual source to confirm all is tight. All good. Taxi to run up to check for normal rpm drop/delta of both ignitions; all good. Flew since first instance 4 times now with no more issues on shut down. Sunday flew to KTVL for breakfast with the better half and again....stumble on shut down; had to engage choke to get it shut down. After breakfast, started up fine, flew back home, same issue on shut down at home hangar.
Instinctively; I think I know what you guys are going to tell me to do; but thought it best to describe in detail what I experienced first.
Advice and direction is greatly appreciated!
2011 RV12 # 120201 395 hours
Old 11-24-2020, 04:44 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Sounds like one of the CD ignitions is not shutting off. Could be bad panel switch or intermittent connection to main panel.
Try shutting off one ignition at a time in cruise flight. You should notice a reduction in RPM when each ignition is shut off.
Try shutting down engine ignitions instead of A then B - try B then A.
Try shutting Master Switch off then shut ignitions per above...
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 633
Old 11-24-2020, 04:59 PM
DHeal DHeal is offline
My RV-12 experienced an intermittent internal failure of one of the panel-mounted ignition switches. It is a relatively easy fix with a new switch being available from Van's.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 990+ hours (as of Jan 2021)!
VAF donation through June 2021.
Old 11-24-2020, 09:21 PM
From your description it might be “dieseling”. Does it run hot?
Old 11-24-2020, 11:22 PM
NinerBikes NinerBikes is offline
I believe your idle speed should be set to 1650 rpm or less.
I turn off one ignition system at a time, with throttle set at the idle stop.
This makes the shut down of rotation of the prop much less violent when the rotation stops through the gear box.
2020 Dues paid
N72DJ, RV-12, bought flying. A Blessing in disguise. Thank you Double D!
Old 11-25-2020, 12:21 AM
PaulvS's Avatar
PaulvS PaulvS is offline
What spec are you using as a reference for the 912ULS? If idle speed is too low it is hard on the gearbox and causes wear.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 11-25-2020, 07:16 AM
Piper J3's Avatar
You are correct, uneven firing pulses at low speed is bad for the gearbox. Yes, set idle for ~ 1600 so engine can be slowed sufficiently in the air for good aerodynamic braking when prop is being back-driven in a glide. When engine is being back-driven the gear mesh is loaded heavily in one direction and gears run smooth. As airplane touches down the pilot must advance throttle to operate in green arc on the ground. Gears and rotating elements (bearings) can take a lot of abuse if rotating at high speed. Envision wheel bearings on a car hitting a huge pot hole. As long as wheel in rotating, rollers/ bearing race are OK. Now hit a bearing with hammer during installation and you have added small flats on the rollers and bearing will fail.
I start and warm my engine at ~ 2700 RPM so that initial uneven running of cold engine appears smooth for the gearbox. My shutdown procedure is idle slightly above 2000 RPM when switching off ignitions. Engine has over 600TT and gearbox is like new. Relative “health” of gears and drive dogs on overload clutch can be “inspected” by feel and sound when burping the engine for oil level check. Turn the prop slowly and feel for backlash in the drive dogs when compression goes over TDC. Also rock the prop back/forth to feel gear mesh. Make a good mental picture for future comparison.
Jim Stricker
EAA #499867
Old 11-25-2020, 07:41 AM
DBRuth DBRuth is offline
Default Operator's manual
You might want to read the operator's manual and see what it says about dieseling and proper shut down procedure. I have not looked at the procedure lately so I can't remember the instructions. The idle on my engine is set about 1600-1650, but I don't ever operate that low. Try not to let it get below 1950revs at any time. My shut down procedure is to reduce idle to 1950 momentarily, then back to min idle and quickly shut off one ignition, watch for rpm drop, and quickly shut down second ign. Engine temperature and fuel quality/octane can also cause run-on/dieseling.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @305
Dues paid 2020
Old 11-25-2020, 07:50 AM
JBPILOT JBPILOT is offline
Default My experience - -
I had the same thing 2 - 3 years ago. Finally found the small connector with the two 'kill' wires must of had a little corrosion. Put electric cleaner spray on connector halves. Then dielectric grease. Fixed it. Simple to try.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
Old 11-25-2020, 03:47 PM
Thanks for the responses guys. A few answers to questions raised and another question:
JBPILOT and DHEAL - I think you're both talking about the same thing.(?) Is access for the switches from the front instrument panel or from the top through the avionics bay?
DBRuth and RFScaller - plane doesn't run hot and what is dieseling? I run 91 octane mogas 90% of the time and 100LL cross country. Occasionally i suppose I could have up to a 50/50 mix of the two in the tank as well.
Piper J3 - I will try the 3 tests in your reply from yesterday.
And here I thought all responses would point me towards the dreaded floats!
