Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 11-15-2020, 02:27 PM
polkaking27 polkaking27 is offline
Default GDL 50 hardwire to G3x touch- Help!!!
I just wired in my GDL50 using the bare wire connector) to my g3x touch. I decided to wire it in because whenever I connected via Bluetooth I wouldnít receive traffic on my g3x.
Using the bare wire garmin connector and port 4602, I pinned the green wire to #29 and green/white to #13, then ran power and ground. When I power on the GDL turns on just fine.
What do I do from here??? I canít find instructions ANYWHERE on how to configure the G3X to recognize the GDL50. Any advice or links to configuration instructions
Old 11-15-2020, 02:52 PM
Longez's Avatar
Longez Longez is offline
Post
Polka,
As shown on page 27-24, configure the GDU 4XX RS-232 port connected to the GDL 5X/5XR to "CONNEXT 57600 BAUD".
Steve
Old 11-15-2020, 07:54 PM
Thank you so much for this, I'm not sure how I overlooked that. New question though... Would I set it up the rs 232 with the "connext 56700 baud" (it says that is for 51r/52r)
Or would I follow the rs-232 GDL39 protocol "Garmin Data transfer" since I'm essentially using the GDL39 bare wire connection and the portable GDL50 is not included on the first option?
Thanks again
Old 11-15-2020, 08:58 PM
Longez's Avatar
Post
Thanks again
You don't have a GDL 39/39R, so you should not use the configuration for those devices.
Use the "Connext 57600 Baud" configuration for the GDL 5X/5XR.
Steve
Old 11-24-2020, 09:18 AM
So I’ve connected that rs232 port to connext 57600 baud and I get the green check mark. Test flew it yesterday and I didn’t get any traffic input. Do I need to change both traffic and weather inputs to the gdl50 somehow.
Old 11-24-2020, 10:04 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GDL Traffic Information
So Iíve connected that rs232 port to connext 57600 baud and I get the green check mark. Test flew it yesterday and I didnít get any traffic input. Do I need to change both traffic and weather inputs to the gdl50 somehow.
Good Morning,
Which transponder do you have interfaced to your G3X Touch system? Do you have TIS-A Traffic Data enabled in the Transponder Configuration menu?
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 11-26-2020, 08:52 AM
I have a gtx23es installed and it’s set for both transponder and trfc functions
Old 12-08-2020, 12:08 PM
Any Ideas Justin???
Old 12-08-2020, 04:56 PM
g3xpert's Avatar
Default G3X Transponder Configuration
Any Ideas Justin???
Will you please email us a screenshot of your transponder configuration page to G3Xpert@Garmin.com, so we can take a look at your settings.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 12-08-2020, 07:36 PM
Longez's Avatar
Post
It would also be good to grab a screen shot of your Traffic page so we can see what you are seeing that causes you to say "I didn't get any traffic input".
This is from my Aera 760 connected to a GDL 52R inside my plane, but my G3X Touch (which is currently using the GNX 375 provided traffic/weather) has a similar traffic page. The top left of the traffic page shows the traffic source which is being used (GDL ADS-B in this example).
You should disable TIS-A traffic on your GTX 23ES configuration. Your GDL 50 ADS-B traffic blows it away.
Name:	GTX Config.png
Steve
