Old 10-09-2021, 07:30 AM
LUKLA's Avatar
LUKLA LUKLA is offline
Default RV 12 Main wheel and nose wheel Bearing....
How often you all replace main wheel and nose wheel bearing replace??
Mine main wheel bearing went bad in 100 Hrs with in 2 years!!!
Nose wheel went bad in 170 hrs With in 3 years !!!
Just curious is it normal or Something wrong with my plane !!!
Experts Opinion are well Come....
Lukla
Glendale AZ
RV-12
N316AM
Flying since June 2018
150 Hrs and Counting
Old 10-09-2021, 07:39 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Explain what you mean "Wheel Bearings went Bad"
How did you diagnose problem?
Very unusual for taper roller bearings to have problem...
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 780
Old 10-09-2021, 07:48 AM
Walt's Avatar
Walt Walt is offline
I see many folks over tighten taper bearing pre-load, this will cause premature failure.
General rule 'hand tight' is pretty close to the correct pre-load for taper bearings.
(then loosen enough to get the cotter key in)
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 10-09-2021, 07:51 AM
LUKLA's Avatar
Went bad means seal came out and little balls came out. I can hear grinding noise while taxing.
FYI Bearing # 1628RS
Lukla
Glendale AZ
RV-12
N316AM
Old 10-09-2021, 08:42 AM
Piper J3's Avatar
I guess that's possible on front wheel which has ball bearings.
Main wheels have tapper roller bearings and nothing can fall out if seal fails. Taper rollers are virtually indestructible.
Old 10-09-2021, 08:52 PM
rk2436 rk2436 is offline
Read the Matco instructions. These bearings are installed different from traditional roller bearings. Your doing something incorrectly.
Old 10-09-2021, 09:08 PM
My bearings are 10 years in service averaging a little over 100 hours per year with no problems. They seem pretty durable and trouble free.
Old 10-09-2021, 10:08 PM
DHeal DHeal is offline
Over 1,000 hours / 7+ years and all my wheel bearings look and run like new. The Matco main and nose wheel bearings require different maintenance techniques. Best to follow Matco recommendations.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,170+ hours (as of May 2022)!
VAF donation through June 2023.
