Go Back   VAF Forums > Model Specific > Rocket
Old 01-14-2021, 10:20 AM
cduster cduster is offline
Default Induction air setup with Airflow Performance
Hello gentlemen,
I am thinking about doing away with the ram air setup on my HR2 and going with something that includes a full time filter. This would be with the forward facing Airflow Performance induction. Has this combination been done much before, and if so, whats it look like on the exterior of the lower cowl?
Craig
Old 01-14-2021, 05:51 PM
titanhank titanhank is offline
Originally Posted by cduster View Post
Hello gentlemen,
Craig
I have the rear facing injection system on my rocket. I talked to john harmon a few months ago and he mentioned he had a kit to turn it around and connect to the existing air intake. I have not pursued it yet, but i would like to get rid of the unfiltered ram air.
Harmon Rocket #1
IO-540
10-1 pistons
1959 Piper PA22-150 Tri-Pacer
Rv7a sold
Rv6 sold
Rv4 sold
Rv3 sold
Old 01-23-2021, 06:41 AM
I-TERA's Avatar
I-TERA I-TERA is offline
Hallo Craig,
I modified my lower cowl to accept an inlet and a reversed conical filter mated with a canister providing an alternate air intake and a flange to be connected with the Airflow Performance metering unit via a short flexible silicon duct.
The inlet and filter are removable from outside to inspect and clean.
A strong lip avoid any movement of the filter toward the engine also if pushed by foreign object.
The sump is a Barrett cold air.
Here some pics and drawing:
https://www.dropbox.com/sh/1o57quevc...-Lqi4bV6a?dl=0
Claudio
Claudio Ricci
F1 Rocket EVO
Old 01-27-2021, 07:13 AM
Thanks Claudio, that looks like a very clean and compact design. Am I safe in assuming that you see manifold pressures very close to barometric pressure?
Old 01-27-2021, 01:57 PM
I-TERA's Avatar
Yes, if WOT at 200kn , the manifold is a little higher than the static ( difficult to appreciate ). At low speed and full power ( take off ) the pressure is a bit greater than static due to the proximity of the inlet to the propeller.
Claudio Ricci
F1 Rocket EVO
Old 01-28-2021, 01:46 PM
Aden Rich Aden Rich is offline
Default RAM Air
While the original HR2 inlet was never really "RAM" air because of the way the alternate air source selector was made. If you had the selector on outside air, the gate was parallel to the sidewalls and allowed any excess air that the engine was not pulling in, to bleed out the side that was attached to the alternate air ducting. Any excess was just blowing into the side of the cowling.
F-1 Rockets had a scoop with an air filter and you can buy the inlet that needs to be mated to your cowling with their filter.
You can also use something in between and is a nice product that Rod Bowers makes that is true "RAM" air and has sprung flaps that in the event of blockage, the suction of the engine will pull them open. The RAM air pushes them closed and all the forward motion of the airplane plus the prop pulses are compressed into this induction. I know folks that have this and get 1.5 inches increase over stock at cruise.
I like the looks of the Rocket myself so you could remake the Y inlet to have two gates with two control cables that would have to be used when using alternate air. The 2nd gate would fully close off the alternate air throat and then all the "RAM" air would go into the engine. http://www.ramairforhomebuilts.com/products.html
Aden Rich
Never met an airplane I didn't like!
Old 01-28-2021, 01:51 PM
DanH's Avatar
DanH DanH is offline
https://vansairforce.net/community/s...t=44856&page=2
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-28-2021, 06:29 PM
When ram air cable is pulled, i get .5 hg rise. Not worth the trouble in my opinion.
Harmon Rocket #1
IO-540
10-1 pistons
Rv7a sold
Rv6 sold
Rv4 sold
Rv3 sold
