Old 02-19-2021, 09:34 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Fuel leak indicators
Currently doing my annual. We've lined the center tunnel with black sound-deadening foam, and that coupled with the blue anodized fuel fittings makes searching for fuel leaks neigh-on impossible with just a flashlight and a pair of eyeballs. I can neither see nor smell anything out of the ordinary.
I thought of lining the tunnel floor with a couple of white paper towels so at the next annual I could see leaks much better, but instantly rejected that as a fire hazard (we all know how hot that tunnel can get).
Trying to come up with a better way to do this. Suggestions anyone?
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
50 hour oil change: 8/29/19
Old 02-19-2021, 10:11 AM
Ron B. Ron B. is offline
You're worried about the paper towel fire hazard but not the foam?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 02-19-2021, 02:25 PM
ppilotmike's Avatar
Yank the foam and paint the tunnel white.
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 02-20-2021, 10:31 AM
lr172 lr172 is offline
+1
I would much rather have 2 sheets of paper towel burn than all of that black foam. WAY less toxic. Also, if you are leaking fuel in there, I would suggest that your fire risk is much higher than paper towels. Fuel will light much easier than paper.
Either way, the risk is low. If you have a source of heat that can spontaneously ignite a paper towel in your tunnel, you have much bigger problems than the fumes from the paper towels.
Just one mans opinion.
Larry
Old 02-20-2021, 01:49 PM
9GT's Avatar
9GT 9GT is offline
I wrapped the fuel fitting joints with a small piece of white paper towel and scotch taped them in place. Opened them up every time I had the tunnel cover off to check and verify no blue stains from a leak and replaced them. Like mentioned, you have bigger issues if you have a fuel fire in the tunnel than a couple small pieced of paper.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 02-20-2021, 02:19 PM
Roadjunkie1's Avatar
Roadjunkie1 Roadjunkie1 is offline
Find the thread on foam insulation reacting with the aluminum tunnel and floorboards and, well, for lack of a better term, rotting them away! The pictures looked VERY scary.
Michael
RV-4 2860
1946 C-90 J-3 Cub
Old 02-20-2021, 04:43 PM
Ralph Inkster Ralph Inkster is offline
My method of checking for fuel leaks at fittings is to wrap my (clean dry) finger around the B nut and check for dampness, I don't solely rely on visual cues. & is my practice to touch every fitting during annuals, & usually every time the cowling comes off too.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
