Old 02-11-2021, 05:04 AM
David Z David Z is offline
Originally Posted by PaulvS View Post
If retrofitting such a stiffener to a completed fuselage, what would be an effective method of dimpling the skin? The skin is too thin I guess for machine countersinking, and the pulled rivet tool dimplers make a dimple that is a bit on the shallow side.
Seems like the perfect spot for pop rivet dimple dies on an assembled airplane.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage started
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 02-11-2021, 05:58 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Not absolutely needed to rivet this stringer. It would be better yes, no question. But if you glue it on with scotch weld or pro seal or even 3M VHB tape ... this would already dampen/reduce/stop the oil caning situation.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 02-11-2021, 10:15 AM
Low Pass's Avatar
Low Pass Low Pass is offline
~2200 hrs, approaching 21 years. No issues there.
Bryan
Houston
