Old 09-14-2021, 08:23 PM
fehdxl fehdxl is offline
Default RV-12iS Flap Motor Broke
Has anyone else had the flap motor come loose from the rest of its housing?
Looks like we’ll be purchasing a new ES-FA-PO-150-12-2…can’t right now because Van’s store on the web is a mess…not loading or searching correctly. :-(
Thanks!
-Jim
ID:	15829  Click image for larger version
Old 09-14-2021, 08:34 PM
Bob Y Bob Y is offline
How many hours on it? I’m at about 110 with no issues.
And if Van’s source is an issue, here’s the link directly to Firgelli.
https://www.firgelliauto.com/product...UaAmDBEALw_wcB
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 09-14-2021, 10:36 PM
Thanks Bob. 70 hours since first flight in February 2021.
Old 09-15-2021, 03:41 AM
Karl Kistler Karl Kistler is offline
130 h since July 2020
Old 09-15-2021, 10:51 AM
rvbuilder2002's Avatar
Thanks!
-Jim
Hi Jim,
We would like to get more information regarding this.
Could you please file a report using the method described on page 17-1 of the Maintenance Manual (I have attached a copy below for your convenience).
Use any method you wish. The feed-back form (also attached) can be used as a guide for the type of information to provide, but it is not necessary to actually use the form... just the appropriate info type in an e-mail is fine.
Name:	RV-12iS M.M. page 17-1.jpg
ID:	15843  Click image for larger version
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-15-2021, 06:45 PM
Scott, I will. BTW, spoke with and sent some pictures to Greg today. -Jim
Hi Jim,
Old 09-15-2021, 11:58 PM
In the interest of safety, I’d recommend anyone who has the center cover off of their RV-12iS, inspect the flap motor for movement or looseness. Here’s a picture of the screws that came loose. As a general rule, all fasteners need a locking mechanism…in this case there was none. A lock washer or loctite would be acceptable in my lay opinion.
Additionally, while we were disassembling the flap assembly, the internal wires just pulled apart…held together with a half twist and heat shrink… no solder or crimp anywhere. Definitely not aviation standard methods from what I know.
Fly safe!
Jim
ID:	15869  Click image for larger version
