Old 09-11-2021, 05:45 PM
WJaviation WJaviation is offline
Default Timming Canopy help. (Pics)
]Iím curious how much trimming if any was required to trim your canopy.
Ive got my canopy up on the frame and aligned as absolutely as well as i can get it and it appears that i will have to trim at least 1/8th inch off the bottom of the canopy on BOTH sides where it meets the frame in order to satisfy the instructions.
Ive read posts in the past were folks left the canopy mostly untrimmed with left and right sides resting on the frame.
Cutting a full 1/8th off both sides FEELS very excessive, like I'm missing something or doing it incorrectly. Iím hoping that i simply am aligning my canopy incorrectly somehow and donít actually need to make cuts like this.
Could my canopy frame simply be bent in some strange way that Iím not seeing? Or is 1/8th inch trimming normal to get the canopy to fit the way it's intended?
ID:	15709  Click image for larger version
Old 09-11-2021, 06:22 PM
GatorsR1's Avatar
GatorsR1 GatorsR1 is offline
I'm just one data point, but my canopy fit nicely and needed no trimming.
I also found that, on all the fiberglass parts (tail cone, cowling, wheel fairings, etc), the trim line was just about perfect for final fitting of those parts.
I'd double (triple?!) check whenever anything doesn't fit per plans.
Bob Costello
RV12 #120764
Support VAF "if you read it, buy it"
Old 09-18-2021, 09:12 AM
kevinl4000's Avatar
kevinl4000 kevinl4000 is offline
Normal. I had to sand down the right side 1/8th, maybe a little more. The left side less than 1/16th.
Kit #120-666 "The number of the beast"
http://kevinsrv12build.blogspot.com
Old 09-18-2021, 02:43 PM
AeroDog AeroDog is offline
Location: New London, NC (near Charlotte), Longmont, CO
I had to trim quite a bit on the sides to get the called-for 1/8th inch clearance with the canopy in a relaxed state.
Jerre
RV-12 120593 N42KJ reserved
Avionics done, engine in progress
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2021
Old 09-22-2021, 02:36 PM
JwWright57 JwWright57 is offline
Jerre
Same here my canopy required a bit of trimming
Jeff Wright, Charlotte NC
Rv-12is with 912is and Dynon system.
Certified Aug 2021
Dues paid 2021
