I have Cleveland master cylinders 10-30 and the o-rings are now leaking because of the 83282 brake fluid and the old nitrile seals. I failed to replace them when I upgraded the caliper o-rings.
I need to replace them with Viton rings but need the correct sizes to order.
Does anyone know off-hand the correct sizes or part numbers?
Will probably order from O-ringUSA
Glenn Wilkinson
Glenn Wilkinson
