My upper longerons are bent as shown in the plans. They fit pretty well on both sides. Ship forward they angle in and down to match the weldment angle. This inward angle obviously should carry aft to the mid brace.
But further aft it seems necessary to rotate the angle so the outside face is vertical. The bend at the baggage bulkhead F-807 seems the right place to put in that twist up and out.
Did I miss the rotation in the plans? Or is this a twist to fit situation? Is my estimation of where to insert the correcting twist correct?
