Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
View Poll Results: In calm winds, at what speed(KIAS) do you normally land your RV-10?
<70
19 |
51.35% |
70
8 |
21.62% |
72
2 |
5.41% |
74
4 |
10.81% |
76
5 |
13.51% |
78
0 |
0% |
80
1 |
2.70% |
>80
0 |
0% |
Depends on how I feel that day
3 |
8.11% |
None of the above
1 |
2.70% |
03-06-2023, 02:42 PM
Originally Posted by gasman
You actually can't land the aircraft without stalling the wing. If the wing is not stalled, the wing is still flying and the brakes are not very effective until the wing is stalled.
1.
Sorry for the thread drift….
The above statement is simply not true. Not saying that landing at minimum possible speed is not desirable. But it’s not a necessary condition. Remember a stall - a disruption of smooth airflow attached to the wing - is a function of angle of attack, only. When all three wheels of a nose gear airplane are on the runway, the angle of attack is near zero, so little lift is generated. But the wing is not stalled. Same thing for a TW airplane doing a ‘wheel’ landing.
03-06-2023, 04:31 PM
Originally Posted by rocketman1988
Not true. The wing does NOT need to be in a stalled condition to land…and in cases where there is any type of gust, you do not want to be right at stall speed, especially on approach.
Typical approach speeds are around 1.3 Vs, at gross approximately 72 knots, slowing over the fence to something less than that. If it’s gusty, add a few knots to increase the margin. I prefer half flap landings in my -10 and use about 76 knots on approach, give or take.
I definitely agree that your speeds should be predicated on your specific airplane; each one is just a bit different.
Sorry for the confusion..... I expected that everyone understood needing adjusting approach speed based on conditions.
You will notice, I was not talking about approach speeds.
VAF #897 Warren Moretti
2022 =VAF= Dues PAID
03-06-2023, 04:55 PM
…and you need to understand that landing with a wing in a stalled condition is neither required or recommended in most cases.
Also, every landing is preceded by an approach; that approach is an important part of the landing.
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
In Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2022,...Thanks DR+
You are correct! I should have said..... no longer creating lift.
03-06-2023, 04:59 PM
That is an incorrect statement as well…
Bob
EAA Tech Counselor
RV-10-ER
N464RL
In Paint at Evoke!
03-06-2023, 05:01 PM
The OP was not talking about approach speed.
03-06-2023, 05:16 PM
In order to "have landed" the wing must be producing less lift than the weight. It is not necessary that it create zero lift. Obviously braking is reduced when there is residual lift.
But the normal Van's mantra for landing tricycle airplanes is to hold the nose wheel off as long as possible. In doing so, the wing is making "some" lift. For a good touchdown, the wing is producing lift essentially equal to weight. Hold the nose there as you decelerate and the lift decays with reducing speed.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
03-06-2023, 05:17 PM
I KNOW that. You are completely missing the point but that’s ok.
Bob
EAA Tech Counselor
RV-10-ER
N464RL
In Paint at Evoke!
03-06-2023, 05:49 PM
How about.... no longer creating enough lift to sustain flight.
03-06-2023, 05:55 PM
Sorry, nope.
Bob
EAA Tech Counselor
RV-10-ER
N464RL
In Paint at Evoke!
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
