w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-16-2020, 07:30 AM
Jvon811's Avatar
Jvon811 Jvon811 is offline
L.D.,
You are correct, the last two pictures are of the pitch servo setup. The roll servo mounting location in my airplane is as you see it in the picture. The change in geometry I referred to was the pushrod and clearance hole in the fuse structure. My airplane origially had a NavAid Devices wing leveler and that clearence hole (in the pic) didn't fit my GRT Servo geometry.
The only Mod I had to made to the mounting bracket to clear the footwell was to lower the Servo mount as low as possible on the bottom of the aircraft to clear the footwell. Maybe somewhere around 3/4"-7/8" lower than the standard GRT mount (similar to Dynon and Garmin). I just lowered the mounting holes that bolt to the servo body and removed the excess at the top of the mount. The footwell depression clears the servo now by about 3/8".
-Justin
RV-4 N249P
O-320, Dual P-Mags, Warnke Prop, Short legs, Manual Flaps, GRT Sport EX
Old 09-16-2020, 08:37 AM
Scott Hersha Scott Hersha is offline
Another possible location for the roll servo on an RV4. Easy location to access and inspect.
Click image for larger version
Photo might be upside down or sideways.
SH
RV6/2001 built 2000/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/August 2022 build - Flying
Cincinnati, OH/KHAO
DEC2022
Old 09-16-2020, 06:00 PM
Fly2eat Fly2eat is offline
Smile
Originally Posted by FinnFlyer View Post
Can easily be in the RV-4 stick well so won't interfere with passenger foot wells.
And the "bracket" attached to the stick weldment is very easy to make.
Finn
That's an interesting solution and would solve several of my issues!! Thanks for posting FinnFlyer!
L. D. Jeffries
RV-8 N65KJ "Fifinella"
Building RV-4 #2593
Poplar Grove, IL (C77)
603-491-4175
ldjeffries@gmail.com
Old 09-16-2020, 06:29 PM
Thumbs up
Originally Posted by blackbeard10 View Post
This is how I did mine. I have rear seat footwells. This photo is from gikonhome.blogspot.com. , a super build site from a British RV 4 builder.
He did a fantastic job and a lot of helpful tips and tricks. Thanks for posting. I read his blog some time ago.
L. D. Jeffries
Building RV-4 #2593
603-491-4175
Old 09-16-2020, 06:30 PM
Originally Posted by Jvon811 View Post
L.D.,
Perfect Justin! I am thinking this will work as you describe.
L. D. Jeffries
Building RV-4 #2593
603-491-4175
Old 09-16-2020, 07:36 PM
FinnFlyer FinnFlyer is offline
Actually the pictures and pdf file are from the guy that sold me his Dynon servos.
Today I just finished re-making the angle or bracket that attaches to the stick weldment in steel today (had done it in 0.02" alu to check the geometry when I first installed the servo).
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 09-17-2020, 09:06 AM
Finn
Mornin Finn, do you by any chance have some shots of your re-do on the roll servo bracket?
L. D. Jeffries
Building RV-4 #2593
603-491-4175
Old 09-17-2020, 12:49 PM
Default Stick assembly to servo link bracket.
Used 4130 1/16" plate. Beefier than needed.
Really the only point I wanted to strengthen was around the 3/16" hole for the link to the servo arm. Should probably have made it with 1/16" alu and enlarged and put a small bushing in that hole.
I'll update this post with more pictures later when re-installed.
Added link to pdf file with dimensions for servo mount bracket. Shows up a a black square below. Click on it to open or download.
Do not take my dimensions as gospel. Mock something up with cardboard or thin alum. Make sure you get the servo throw you want. That link doesn't bind on bend nor servo arm. That you have room for nuts underneath screws (or bolts).
Finn
ID:	2560  Click image for larger version
ID:	2561  Click image for larger version
ID:	2585  Click image for larger version
Old 09-23-2020, 08:08 AM
Finn
Thanks Finn. That setup will work without affecting the back seat heat or the foot wells. Thanks for sharing!
L. D. Jeffries
Building RV-4 #2593
603-491-4175
Old 11-12-2020, 06:38 PM
Default control springs on your photo
Finn
Hi Finn,
What is the bar that parallels the control stick that has the control springs attached at the bottom? It's rather long and runs up the stick in the picture. I'm wondering if there is any reason why the springs could not be incorporated into or on the manufactured servo attachment plate instead of on the bottom of the stick?
L. D.
L. D. Jeffries
Building RV-4 #2593
603-491-4175
