w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-14-2023, 12:11 PM
SpeedyMedina SpeedyMedina is offline
Default under wingroot conection
Hello Guys/Gals! I have a Question, in the RV-9 wingroot you have the fairing that came from the rear top of the wing and go under the wing in the front but don't go all the way to the back in the bottom part, and there you have a aluminum part that came from the fuselage. My question is that part in the bottom of the fuselage its bolt to the wing or just cover that area without any bolt or screw?
thanks in advance for any help!
Edwin
Old 03-16-2023, 11:11 AM
RyanWhite RyanWhite is offline
Default There are screws that attach the fuse fairing to wing
Check your plans and instructions - you match drill the holes and screws attach the metal from the fuse to the wing. DWG38
______________
Ryan White
First Flight RV9A 12-18-22
Polk City, Iowa
2023 Dues Paid
