Old 10-02-2021, 09:31 PM
blaplante blaplante is offline
Default 6A IO-320 Catto
Mine:
6A, IO-320 Catto 2 blade Prop
Empty CG 70.4"
RV6A in phase 2 as of April 2016
Donation made Oct 2021
Old 10-02-2021, 10:09 PM
eaglen92ce eaglen92ce is offline
Mine:
RV6
Angle Valve IO360
Extended Hub Hartzell BA Prop
70.6" CG Empty
Bill York
Stellar Airpark (Chandler AZ)
RV-6 N477DH
Eagle II N92CE (sold)
Hiperbipe N777HT (sold)
PA22-160 N9322D (sold)
Old 10-04-2021, 04:52 PM
SEFlyer SEFlyer is offline
Default Thanks
Thanks for all the replies. Good to know we are in the ballpark
Future RV owner
Donation Made
Old 10-05-2021, 07:03 AM
219PB 219PB is offline
Default RV-6A
Mine has a 360 with Hartzell constant speed metal prop. 70.11". Nose heavy. But on the other side, if I have full fuel, max baggage, gross weight, the CG is right at the aft limit. Will not go past.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 10-05-2021, 07:20 AM
Mel's Avatar
Mel Mel is offline
Be careful. With this scenario, as soon as you burn off any fuel, you will be out of aft CG limit.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-05-2021, 08:12 AM
LouFly's Avatar
LouFly LouFly is offline
IO-320 Hartzell CSP Slider Steam Gauge IFR 1105 lb. 71.5 in.
Good point, yes, possible to load aft of CG with pax, full baggage and lower fuel.
100 lb. is a lot of baggage though.
Bob Miller
RV-6A
2021 -=VAF=- Contributor
Old 10-05-2021, 02:24 PM
Mel,
I was mistaken, I typed before my brain thought correctly. Empty fuel, full baggage, two passengers my size (175lbs), puts me right at aft CG. I have a spreadsheet and any way I load the plane within its limits, never puts the CG past the aft point.
Sorry,
Paul
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old Yesterday, 03:19 AM
Dakbuster Dakbuster is offline
With 2 up, max baggage, max all up weight on take off When i burn off fuel down to minimums i am at aft CofG.
I purchased a bison mountain RV bag. this fits neatly over the flap actuating bar so i put most of my overnight gear in the bag and calculate
the moment from the flap control and i never get close to going out the back
Bruce Black
New Zealand
RV6 finished and flying.
