Old 10-01-2021, 01:33 PM
Michael Wellenzohn's Avatar
Michael Wellenzohn Michael Wellenzohn is offline
Default Standby alternator on vacuum pad installation pictures required
Hi,
I am planning to add a standby alternator on my TMX-IO540 which has the 45į oil filter adapter installed (see pictures).
I read that an extension for the oil filter and alternator is required but I struggle to see where the interference would be.
The second picture shows the installed engine with the vacuum port, and angled oil filter in the background. Sorry for the bad picture quality.
Has anybody installed a B&C BC410-H or Planepower FS1-14 standby alternator with pictures of their installation?
Kind Regards
Michael
Click image for larger version
ID:	16553  Click image for larger version
RV-10 builder (flying)
#40511
Switzerland
Osh?18 OWW volunteer
Countries HB-YNN has visited:
🇨🇭 Switzerland, 🇩🇪 Germany, 🇦🇹 Austria, 🇮🇹 Italy, 🇭🇷 Croatia, 🇫🇷 France, 🇪🇸 Spain, 🇵🇹 Portugal, 🇸🇮 Slovenia, 🇭🇺 Hungary, 🇷🇴 Romania, 🇷🇸 Serbia, 🇨🇿 Czech Republic
www.wellenzohn.net
First flight Video: https://youtu.be/X7EQ81C3xSA
Old 10-01-2021, 01:42 PM
Ron B. Ron B. is offline
If your going to install one , please be advised to do so before installing the mag. Just finished installing one and didn't want to touch the E-mag that was factory installed and one nut was almost impossible to get started and then torqued. Once started , torqueing was just manufacturing/modifying a wrench and welding a socket to it.
Can take a photo but it's installed on an IO-390.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 10-01-2021, 02:06 PM
BlackhawkSP's Avatar
BlackhawkSP BlackhawkSP is offline
Originally Posted by Michael Wellenzohn View Post
Hi,
Kind Regards
Michael
I rooted through some of my build pictures. I hope these help. It's no big deal, but you will need the extension.
ID:	16561  Click image for larger version
ID:	16562  Click image for larger version
ID:	16563  Click image for larger version
ID:	16564  Click image for larger version
Larry Anderson
Indianapolis
RV-Super 8 N88XT SOLD
RV-10 QB N38LA Flying
Helicopter Instructor Pilot
Standardization I.P.
Instrument Examiner
U.S. Army Retired
EMS Pilot for LifeLine
At IU Health Retired :-)
Although Exempt,
Donated for 2021
Old 10-01-2021, 02:45 PM
Thank you for your pictures Larry. It looks to me as if the oil filter adapter on my TMX-IO540 came already with an extension from the factory. Comparing the pictures it looks as if Iíll only need the extension for the alternator.
Kind regards
Michael
#40511
Switzerland
www.wellenzohn.net
Old 10-01-2021, 04:13 PM
rapid_ascent rapid_ascent is offline
I'm not sure about the 540 but on the 360 and my 370 the extension can't be too long. My engine came with a longer extension, 2" I think and I had to buy a shorter one so that it would work with my standby alternator. I still have the longer extension if that will work for you.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-01-2021, 09:32 PM
rleffler's Avatar
rleffler rleffler is offline
Kind regards
Michael
I would inquire with B&C via email about spacer length since you already have one on your oil adapted to validate itís the appropriate length. I couldnít find any photos, but mine look just like Larryís.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-01-2021, 10:35 PM
dwranda dwranda is offline
Is it possible to install the one nut without removing the pmag? It looks like there is no access to get even a finger in there. I am installing one soon too and it looks to me like my pmag has to come off.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid April 2021
Old 10-02-2021, 04:27 AM
rleffler's Avatar
I had to take my mag off as well as fabricating a tool to get one nut tighten. I used a slim profile ratcheting wrench and cut it down to fit in the space. I donít recall the exact length, but it wasnít much more than an inch. Iíve modified many tools from Harbor Freight for special single tasks like this.
With the profiles of the oil filter, itís spacers, and the alternator and itís spacers, there isnít much room to get tools on all the nuts. But it can be done with a little thought and ingenuity.
Bob Leffler
Old 10-02-2021, 05:56 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Default watch those spacers
Re: those backup alt spacers: Need to be careful that the overhang moment isn't exceeded of the vacuum pump pad. The Lycoming TCDS only allows a max of 25 in-lb and if a 1" spacer is used with that BC410 backup alternator, you're at 24 in-lb. Reference the B&C BC410 drawing and the Lyc TCDS below.
Name:	Screenshot 2021-10-02 043659.jpg
Old 10-02-2021, 09:20 AM
It is possible, took us over three hours on that one nut to get it started. Ended up taping the nut to a small very flexible tubing which allowed the nut to stay lined up while rotating. Made a special crows foot to torque.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
