Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 06-30-2021, 10:23 PM
phloidtrout phloidtrout is offline
replaced my vacuum gear with a G5 and dock mounted 760. updated my com to the GTR 200. It all works together, & I like it a lot.
Old 10-08-2021, 03:54 PM
jhallrv4 jhallrv4 is offline
Default panel
Originally Posted by N605RV View Post
Thanks for all the advice. I've decided on a G5 six pack since I already have a Garmin GDL-50 ADS-B using a Samsung tablet for a display on a RAM mount. As for a new/improved EMS, I chose a used Dynon. Your input was invaluable. Stop by Boulder airport if ever in need of a tied down and endless tools during your x-country trips.
Cheers
Mike
N605RV
So did you get a new panel, or does it still look kinda like this:
Click image for larger version
I read your post on wanting a stick sleeve for the rear pit, and I couldn't remember not doing one. Then I looked up my pics, and realized that with all the different levels of structure around that hole, I decided against, was going to get around to it...didn't happen, obviously!
Jeff Hall/builder N605RV
Name:	2002-11-04 20.07.06.jpg
RV4 Toucan (flying)
Ft. Collins, Colorado
Old 10-14-2021, 09:31 PM
Marlonyoung's Avatar
Marlonyoung Marlonyoung is offline
Default Same Situation
I'm finishing an acquired project, and tonight just removed the vacuum system and vacuum driven gyros. Lost a few pounds there. Having to make the same decision and right now leaning to the Uavionix AV-30, but maybe G5?
Old 10-15-2021, 06:16 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
the AV-30 sure looks like a nice piece of equipment, though it'd better fit an old-timer or antique such as a C-190
I'm a fan of the G5s, having installed a few on different ships, and flown a few hundred hours behind. Easy to install, light, redundant if fitting the back-up battery, and affordable. Fit 2 of them, one as a ADI, the other as a HSI, with batteries, and no more need for those standby gages of times past
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 10-15-2021, 01:27 PM
RVFan671 RVFan671 is offline
Default G5 and AV-30?
I installed one AV-30 along with their tailbeaconX which is ADSB out plus a transponder and controlled via the AV-30. In the future I'll be installing a G5 because I like the airspeed and VSI tape much better on the G5. I have a panel mounted Aera 510 that integrates really well with the AV-30 so itll be the HSI. AV-30 comes standard with a backup battery.
Bought an O-360 RV4 to fly while building a -10.
Emp completed September 2020
Fuse started October 2020
