Old 11-15-2018, 06:48 PM
MConner MConner is offline
Originally Posted by lr172 View Post
The 10 uses 15/6x6 tires. These are a special,reduced diameter tire. The std 6x6.00 tire will have a larger diameter with a similar weight rating. Width should be similar. Obviously, they will not fit the wheel pants without modifications, if at all.
I have 600x6 on my -10 and they work great on our grass field. And yes they fit.
Mark
RV-10
Bought not built
EAA 180
48X
Old 11-15-2018, 06:55 PM
Do they fit "out of the box" or were your wheel pants installed with larger tires (tyres for our British friends) in mind?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-16-2018, 09:03 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
He indicated the -10 was "bought not built," so he may not know the answer to that, but put me down for sure as someone who wants to know. I just mounted the factory 15/6.00x6's on the Matco wheels last night, but will certainly use the full size tires next time around.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 11-18-2018, 09:42 AM
Piplnr65656 Piplnr65656 is offline
Default Bush RV-10
Wasn?t there a guy in Oregon or Washington that made a bunch of modifications to his 10 to improve back country landing? I remember he had modified the front suspension and the post had a bunch of photos of the little dirt strips he had been in. Even a gravel bar.
RV-10 N203DT empennage in process, fuselage on order.
Old 11-18-2018, 12:16 PM
lr172 lr172 is offline
Assuming Ralph's data is accurate, the tire is 3" bigger, with a 1.5" larger radius. If I remember correctly, the manual has you leave a 1" gap on top of the tire. Upsizing would require a minimum 2" gap in order to leave some clearance to avoid rubbing.
I am guessing that Mconner's plane was set up initially for the 6.00 X 6's or the pant mounting was modified when the upgrade took place. I am sure these tire will fit, but the standard pant installation won't accommodate them.
Larry
Old 11-18-2018, 12:48 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Aero Classis 6.00-6 tires
6” tires can be put on a Vans. Ralph Inksters numbers for the diameter change are correct. A standard 5” tire is close to 14” diameter, a 6.00-6 is about 17.5” diameter, a 6.00-6/15 as used on the -10 is about 15”
The aircraft below is with Aero Classis 6.00-6 tires and Sam James 6” wheel pants (you could also use Vans wheels pants, most likely).
I installed the wheel pants with more than the Vans recommended clearance above the tire. As you can see that will require more tire below the pant than most RVs; however, if you want bigger tires you probably intend to use grass strips. With grass strips I see more pant clearance as a positive.
They will weigh more and may reduce your speed. I have data from one -14 that out runs me and a few that do not. There can be a lot of variables with EAB.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 750+
2021 Dues Paid
The Dues Paid note is a reminder for me
Old 11-18-2018, 01:43 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Originally Posted by M McGraw View Post
SNIP
The aircraft below is with Aero Classis 6.00-6 tires and Sam James 6? wheel pants ....SNIP
That is the way to do it.
FWIW, I used the Sam James 6? wheel pant on my RV-10 and recommend them. I however stayed with the standard tire.
Carl
Old 10-14-2021, 07:47 AM
Speedy140841 Speedy140841 is offline
Any suggestions for 14A just about ready for this portion. I ordered Berringer wheels and would like to do tubeless but not sure which tire to choose.
Old 10-14-2021, 09:04 AM
Masterplumber Masterplumber is offline
Default Tried to mount the 6.00/6 's
I just replaced my mains on my 2007 vintage RV10. Fairings were made to Vans spec's.
I accidently ordered the 6.00/6 Aircraft Spruce version of the Monster re-tread and not the 15.
They definitely are larger outside diameter but since I had them, I mounted them on the rims. At least give them a look, they are nice looking tires with a lot of tread. They clearly would not fit with my standard built fairings. The inside fairing touches the tire well before it installs. I had hoped there was enough space but not in my case. I had no desire to redo my fairings so I sent them back and got the 15 " diameter. (At least they came off the rim easily since they were new.)
Just another data point.
John Koonce
N78MU
Old 10-14-2021, 09:25 AM
iwannarv iwannarv is offline
I see a lot of talk about tire diameter and the desire to get better grass/wet/soft performance. While diameter can help with rocks/ruts/holes.... Don't forget that you're also after width, which is where the 5" guys are using the 380x15s.....
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Building, Finish Kit - May '21
Never judge a man by his trim tabs.
