Old 09-30-2021, 03:38 PM
rvdave rvdave is offline
Default Cleveland brake pads
Can anyone confirm the proper replacement Cleveland brake pad is Aps66-11200?
Edit: Per ACS pads are APS66-11200 and rivets are APS105-00200.
Dave Ford
Cadillac, Mi
Old 10-13-2021, 04:06 PM
RV10Pilot RV10Pilot is offline
It looks like there are 3 choices of brake pads for the Cleveland brakes (30-59E) on the 10.
APS66-11200 APS BRAKE LINING (O) $9.50 each https://www.aircraftspruce.com/catal...g_07-20210.php
RAPCO BRAKE LINING RA066-11200 $9.79 each https://www.aircraftspruce.com/catal...g_RA66-112.php
CLEVELAND 66-112 ORGANIC BRAKE LINING $30.50 each https://www.aircraftspruce.com/catal...ing_66-112.php
Will all three work? Is there any significant difference between the 3?
Also, what lubricant / anti seize, if any, are you using on the posts that the backing plate slides on?
Old 10-24-2021, 06:12 AM
Tim Lewis Tim Lewis is offline
Default APS
There were multiple reports of the Rapco pads deteriorating - the edges sort of crumbled. I don't use anything but APS now. Long lasting, good price.
Post lubricant - I shoot some teflon spray on the posts.
Tim Lewis
CFI, A&P
RV-10 N31TD - 1450 hrs
RV-6A N47TD - 1100 hrs (sold)
