Old 10-08-2021, 04:50 PM
bobair43's Avatar
bobair43 bobair43 is offline
Smile rv7a gear retrofit
If any one is or has done the rv7a nose gear retrofit. What problems have you incured
Old 10-12-2021, 01:28 PM
gclark gclark is offline
Default RV7A nosegear
Did this over a year ago per the SB. No great problem encountered. Pretty straightforward procedure. All new parts fitted well and no modification needed. I do not recall any difficulty with the project. Just get everything together and go for it. 5-7 hours should be plenty of time. Surprised if you do not get other response. This was recommended long ago. Antisplat Aero also has kit for the job with very good instructions.
Old 10-12-2021, 02:48 PM
Bevan Bevan is offline
Did the spinner - cowl orientation come out the same as before the engine mount change? Some spinner - cowl orientations are quite close.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-12-2021, 02:56 PM
Ralph Inkster Ralph Inkster is offline
I just received a Retro Kit for the 9A rebuild project. It originally had the long engine mount fitted, so, with the retro mount being standard length (distance from the firewall), I am anticipating some cowl work in my future...
Oh, well, I'm good at making things shorter, much easier than the other way around.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 10-12-2021, 04:09 PM
TigerMan92's Avatar
TigerMan92 TigerMan92 is offline
Default Anti-Splat Nose Job 2
I thought about this for a long time with my 7A. Since I have not landed her on a grass runway, yet, I decided to buy the Anti-Splat Nose Job 2 kit, at a cost of $329.00.
Installation was less than 1 hour and adds a lot of strength to the front gear.
Gene
KOZW
RV-7A, XIO-360, MT CS 3Blade, Slider
AG-5B, N521TT, Sold
AA-5B, N28684, Sold
