mountainride
I have been jacking via the tie down using the vans method of 2x4s stacked with a bottle jack cup and ball arrangement. It works pretty well but it will get side loaded a little bit as load is taken on and off the gear. This works fine for maintenance at home. I need to come up with a solid plan or product to jack via the gear leg or axle if I am away from base. I don't want to carry a jack. I want to be able to use a standard scissor or car jack I can find at any airport. What are people using?
