w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 05-19-2023, 08:14 PM
Tommy123 Tommy123 is offline
Originally Posted by wirejock View Post
No CherryMax in 3/32. You might ask Vans about going up to #4 and using a CherryMax.
I have a variety of home brew bars. I have a thin tungsten that fits almost everywhere. I often taped the heavy tungsten to it for extra mass.
The tight spots were done with a piece of steel thin enough to fit. Even a flat blade screwdriver will work. The heavy tungsten was taped to the steel bar as close to the impact point as possible. It adds the mass. Same problem with rivets near the roll bar if you have a slider.
There are no structural 3/32 Cherry Max rivets. 3/32 Cherry is NOT a Max and NOT structural.
Old 05-19-2023, 08:23 PM
wirejock's Avatar
wirejock wirejock is offline
Default CherryMax
Isn't that what I said?
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 05-19-2023, 08:43 PM
Sorry. You were correct.
Old 05-19-2023, 09:01 PM
Stoo Stoo is offline
That row of rivets are 4's (1/8").
Stewart Willoughby,6
Old 05-19-2023, 09:17 PM
Desert Rat Desert Rat is offline
no, they are 3's until you get to the 1/2 dozen or so up by the firewall.
Here's a picture of the backside.
I'm just looking for a silver bullet and there probably isn't one. I'm going to ponder this for a while and see what sort of Rube Goldberg bucking bar I can come up with.
Click image for larger version
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage almost done
Avionics almost done
90% done, 90% to go
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 05-19-2023, 09:29 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Bucking bar
Something like this bar might work, made from 3/8 thick structural steel angle.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Airframe structure 95% complete, now working on integration, plumbing and wiring.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 05-19-2023, 10:05 PM
PilotjohnS PilotjohnS is offline
Default yup
Yup, I used a chisel with the tungsten bar resting on the chisel a little below the deck. I taped the chisel and bar together so it was easier to hold them at the same time.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
99.9% done
To Go: Cosmetic clean up and a few nutplates
www.pilotjohnsrv9.blogspot.com
or builders log here on VAF: Pilotjohns
Old 05-20-2023, 09:08 AM
wirejock's Avatar
Default Rube Goldberg
It works! Been there, done that many times.
I have a thin tungsten bar. It's about 1/4" thick. Works great for those tight spots. No idea where I got it but I can look it up in my records. When I tape the big tungsten to it, it's really got some mass.
Larry Larson
Estes Park, CO
Disclaimer
Old 05-20-2023, 04:19 PM
rv6n6r's Avatar
rv6n6r rv6n6r is online now
Mild steel 3/8" thick or so (I keep a few laying around for just this sort of thing). Backed up with a heavy bucking bar for mass.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated December 2022
Old 05-20-2023, 04:22 PM
Victory.
I looked at this again after sleeping on it and realized that the whole issue is that the aft lower edge of the forward canopy deck is in the way back there, and it's just a flange hanging in empty space.
Trimmed about 1/4" off it parallel to the longerons and suddenly I had enough room to get a 3/8" thick L shaped bucking bar in there.
Kudos to everybody who can stand on their head and use a screwdriver as a bucking bar, but I've tried stuff like that before and sad to say, thats a skill set thats hit or miss for me. this was eezy peeze.
Thanks for all the suggestions!
Terry Shortt
90% done, 90% to go
#72651
