w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 04-30-2023, 03:14 PM
RA9A RA9A is offline
Default Air filter replacement
Im replacing k N air filter and need to cut a it to place over the accelerator pump
And don’t remember the procedure
Any clues will help
Old 04-30-2023, 03:30 PM
Zero4Zulu Zero4Zulu is offline
I carved my new filter out with an air tool with an abrasive cone, a little at a time until it fits. Then I put cling wrap (Saran wrap) over the carb area that you need to keep Proseal from sticking to. You need to tuck it into the corners around the accelerator pump protrusion so the Proseal will mold into the area nicely. Put the filter on with a gob of Proseal and secure it into its natural position. After it cures remove the filter and remove the cling wrap. Reassemble.
Steve S.
Rebuilt RV6A Flying!
Scio, OR
EAA Ch. 292
Old 04-30-2023, 03:56 PM
FireMedic_2009 FireMedic_2009 is offline
If I’m not mistaken the cutout is only the inside part of the filter, maybe a 1/3 or less of the thickness of the filter. The outer edge is untouched so after the plate is bolted on you should have a tight seal without needing any proseal, correct?
RV-6A IO-320 FP sold
RV3B O-320 160hp
Donated 2018 and continue annually
Old 04-30-2023, 04:02 PM
Thank you
How did you determine where to put the notch
Old 04-30-2023, 08:20 PM
My original he a notch
I don’t remember how I determined where to notch it
Old 05-01-2023, 05:15 AM
Cth6 Cth6 is offline
Default Trial
Originally Posted by RA9A View Post
Thank you
If you have the old filter use it as a template. It will take a bit of tweaking to get it in the right place. Once there I use a paint marker to mark the outside top of the filter and the fab to index it. I put it in two spots either side of the cut. After the Proseal cures, you have index marks that make it easy to re-home the filter. Nail polish would probably work just as well.
RV-9A Flying (X04)
Old 05-01-2023, 08:37 AM
Default Possible E-3322
I used the E-3322 and did not have to make the cut. It fit fine on my FAB but you would have to check yours.
If others have done this I would like to hear any issues or benefits. It appears to work great on mine. Thanks
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
2023
Old 05-01-2023, 05:25 PM
Thank you all for your replies
I made the notch to bi
Old 05-01-2023, 05:27 PM
Sorry about that
I made the notch to big today and have to get a new one and try again
