w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 05-14-2023, 02:53 PM
kirkbauer kirkbauer is offline
OK, I'm continuing this conversation because I think it's the only one out there on this 15-degree bend in the trim tab (in my case, for an RV-10).
But first, the back story. I'm focused on finishing the elevators so I can mount them on my HS, and then add on the tips, so I can transfer the whole HS to my hangar. So I was disappointed when I got to the "let the elevator dry for a few days" step. What am I going to do for 3 days? All I have left is these tiny trim tabs that hardly have any parts!
Well, now I'm not sure if I'll finish these trim tabs in three days. What a pain! I think the instructions are just not very good here. You are supposed to very precisely fold the leading edge and make sure it is perfectly straight, and then you are supposed to use a rivet gun and clamps to fold the ends down, which will mess up your perfectly folded trailing edge. Then you get to this 15-degree bend on the front spar of the trim tab and they don't give any direction at all. I would have loved to clamp it to my workbench with a piece of wood, but I couldn't figure out how how to do that with the end tabs already bent in.
So, if I could do it all again, I think I would first do the 15-degree bend, then I would fold the end tabs, then I would fold the trailing edge. Perhaps there is an issue I'm not seeing with that order, but it sure seems it would be easier.
Finally, back to the 15-degree bend in the leading edge. Here is what I did: I cleco'd the skin to the spar. On the bottom (where I needed to do the 15-deg bend), I cleco'd in every single hole. Then I got my seamers and I just bent the skin against the front spar. It was easy and it looks great. I couldn't figure out another way to do it that wouldn't be problematic. And as a bonus, you can't bend the wrong part of the skin because it is already properly cleco'd to the spar.
I hope this helps somebody else, good luck!
PS - some things that worked for me on the leading edge fold. I used my bench and a 2x4 to start the folding process, and then I fine-tuned it using the brake described in Section 5. I did end up over-folding a portion of one of my trim tabs. Remember those wedges that you had to cut out of the wood blocks to fit the trim tab? Well, I took a wedge, I cut off about 1/2" off of the point, and I rounded the edges on my sander. I now had a wedge that I could put into the skin and tap it down into the inside of the fold. I was able to gently un-fold the part that was over-folded.
Last edited by rv7boy : 05-15-2023 at 11:05 PM. Reason: Bump is a four letter word.
