w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 05-06-2023, 10:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Have you considered using the 3 puck calipers, then playing around with the actuation arm at the pedal to get a different leverage and feel?
Or maybe using a larger bore master cylinder with the 3 puck calipers?
Many ways to skin this feline.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-06-2023, 10:37 AM
Mark33's Avatar
Mark33 Mark33 is offline
That’s a very good point!
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- Sold project
RV-14- Building
Old 05-06-2023, 10:46 AM
DanH's Avatar
DanH DanH is offline
Sure, both. And working from the other direction, Matco offers "intensifier" kits (a smaller master cylinder bore) to increase line pressure with the single piston calipers.
Right now I'm inclined toward a Grove 65-202 (3335 and 170K), but I'd like to hear more about why they recommend the -211.
Originally Posted by Mark33 View Post
It appears as though the RV-14 three 1.25” Matco setup is relatively close to what Groove is recommending (4266 VS. 3974) in-lbs. A persons foot can obviously adjust to how much pressure is needed to apply to the break pedal, or am I missing something here?
You're not missing anything. I'm just looking at the choices and reporting here.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-15-2023, 10:17 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Motorcycle pads - would they fit?
I changed to a sintered pads on my K1200RS - holy **** I know what brakes are now! I’ll bet you could confiscate a set of those to see what happens? Hmmm…..
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
