Paris12Man
Hello, My RV12 has the original flight instruments install (Dynon D180). Recently I have been receiving High Fuel Pressure Alarms from the D180. I sent the D180 into Dynon for an overall inspection and repair if needed. I have received the unit back and have it installed. My first test flight showed the fuel alarm was not resolved. I receive this alarm during climb out, while reducing the throttle to land, and other times during flight. I have seen readouts as high as 15 psi.
Has anyone else experienced this issue? I know I can pull the fuse to stop the electrical fuel pump, but I haven't done that yet. Before I start the tear-down of the cockpit, I was hoping for some helpful suggestions.
Thank you,
Thank you,
