Old 12-19-2021, 06:09 PM
rkiefer2 rkiefer2 is offline
Default Starting My RV8 EMP Kit
I purchased a new untouched RV8 EMP kit that was kitted in 2014. I've got all the tools ready, parts inventoried, shop laid out, etc.
Looking for recommendations on the following:
  • Best place for the "Plan Gothcas"
  • Awesome build logs with pictures to help when I get stuck
  • Any rivet identification, dies <---> rivets <---> drill sizes, etc cheat sheets
Any recommendations is appreciated.
Roger Kiefer II
RV-12 SLSA - Flying/Instructing
Rv-8 Building
EAA Chapter 18 Member
Waukesha, WI (KUES)
Old 12-19-2021, 06:23 PM
N804RV's Avatar
N804RV N804RV is offline
Yep. Here's one and two:
https://www.vansaircraft.com/service...s/sb-14-01-31/
https://www.vansaircraft.com/service...s/sb-14-02-05/
Make sure both of these are incorporated. Also, Even if they are already incorporated in your kit, print out and study them. And, compare the service bulletins to the plans and make sure you understand them before doing anything.
It took me a lot of slow progress on these due to the head scratching involved. From what I've heard, I'm not the only one.
Ken W.
Mount Vernon, WA
2022 VAF Supporter
Old 12-19-2021, 07:17 PM
PhatRV PhatRV is offline
  • Best place for the plan "Gothcas"
If you have limited building experience, it is easy to mess up the trim tab. Good luck
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
Old 12-20-2021, 03:15 AM
Jonnyb's Avatar
Jonnyb Jonnyb is offline
The edge distance on some of the holes in SB 14-01-31 are REALLY tight. Be careful.
RV-8
Empennage done
Wings in progress
Fuselage ordered
Old 12-20-2021, 07:22 AM
N804RV's Avatar
...[*]Any rivet identification, dies <---> rivets <---> drill sizes, etc cheat sheets...
-Buy a #1-60 drill bit guage. This is one of my most used tools.
1. Not sure if that's a #30 or a #31 drill bit?
2. How much do I need to up-size a hole to substitute a CherryMax rivet?
3. I forgot which drill bit to use to final size that hole for an AN509.
- Buy "chuck-able" reamers for #30 #40 and #12. These will give you nicer holes when "final-drilling" pre-punched pieces.
Drill Bit Guage
#30 Reamer
Ken W.
Mount Vernon, WA
2022 VAF Supporter
Old 12-22-2021, 09:00 PM
MIKE JG MIKE JG is offline
You might consider starting with something slightly easier than the horizontal stabilizer. I started with the rudder based on advise I got. The plans are written to have you start with the HS but if you read them and study them thoroughly ahead of time you can easily start with the rudder or even VS if you want.
Incorporating the SB for the front spar of the HS is a bit tricky and like someone mentioned there are a few holes that are right on the edge of what you can safely get away with. To me, had I started with this assembly I think my frustration and cuss word factor would have been a lot higher.
Based on your other post it sounds like your kit does not have the SB's incorporated into it already so take your time and ask questions.
Tool wise, I would agree the reamers and drill bit gauge are good things to have. You will also need a small torque wrench capable of being set to inch pounds as well as a needle type torque wrench to measure the torque drag on the nuts that attach the elevator hinge.
There are instructions written on the construction drawings as well as the plans themselves. Make sure you highlight any build instructions that are on the drawings. Easy to miss those and have to redo a section.
I'm finishing the HS now. My build log below may be of help to you.
-Mike G
Northeast Ohio
RV-8
Rudder completed
Horizontal Stab completed
Working on Vertical Stab
Builder #83203
VAF Dues Paid Monthly
My Build Log: https://eaabuilderslog.org/?blproject&proj=7YG4STHvs
Old 01-01-2022, 01:52 PM
JeremyL JeremyL is offline
Feel free to check out my build log, never know it may answer a question you have or shed light on something. Also Iím in the fabricate riblet camp for the trim tab.
_____________________________________________
RV7A(in construction)
https://eaabuilderslog.org/?s=N524JL
