Old 04-20-2016, 08:28 AM
tsw94r tsw94r is offline
Default Rudder AEX angle
1st time poster
I am working on installing the AEX on the TE
I have clekoed the skins, aex and Alum angle together and have noticed that the AEX strip has a steeper angle than the angle of the skins. This is causing the trailing edge of the skins to leave a gap between the AEX and skins at the TE.
This tail kit is an older kit, 2008
Is this normal or has the AEX changed over the years?
Thanks, Tom
Old 04-20-2016, 08:48 AM
wirejock's Avatar
wirejock wirejock is offline
Default Wedge
Originally Posted by tsw94r View Post
1st time poster
Thanks, Tom
Welcome Tom
Order a new AEX wedge just in case and compare the two.
If you plan to tape or proseal, the gap may be a good thing.
I used proseal.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 04-20-2016, 09:12 AM
Default AEX angle
Thanks Larry,
I am planning to use pro-seal, but shouldn't the TE be a fairly sharp edge?
I also saw in another post about an elevator using the AEX, has this changed or just not for the 7
If somebody could measure the angle of their AEX I could compare mine and decide if I just need to order a new one.
Tom
Old 04-20-2016, 05:29 PM
Default AEX Angle
I measured about 12 degrees on the AEX and about 8 Degrees on the rudder skins. I have the ability to machine the AEX to match the rudder skin angles. I can also just order another AEX, but if 12 degrees is correct, there is no point ordering and if it is supposed to 12 degrees I guess it was meant to be this way for a reason.
Any input or verification would be helpful.
Thanks in advance, Tom
Old 04-20-2016, 05:55 PM
wirejock's Avatar
Default Wedge
I can't get an accurate measurement on the wedge edge but if I look really close, it does appear the wedge is slightly wider. Nothing anyone would see and you need the width to correctly set the double flush rivets.
The 7(a) only has a wedge on the rudder. There are other models with wedge edges other than rudder. Be glad you only have the rudder.
Yes, the edge is the thickness of the edge of the wedge plus the two skins.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-21-2016, 05:36 AM
Default AEX Angle
Thanks again Larry,
I do think I may be over thinking the process. I calculated the gap and it works out to .0131" (not even a 64th) between the AEX edge and either skin. I think I will continue on.
Maybe this is why it has taken 8 years to get to this point.
Tom
Old 04-21-2016, 07:04 AM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
The -9 and -10 have wedges on all control surfaces, so we get lots of practice with this! I like to use an edge roller (very light application) prior to dimpling and it keeps the TE nice and sharp.
Andy Compton
USAF, USSF, Phd EE
RV-10 #41414, N643AC (building)
RV-7A #72158, N808PA (flying)
RV-9A #91638 (built,flew,sold,missed)
Old 04-21-2016, 07:23 AM
PilotjohnS PilotjohnS is offline
Default Trailing edge shape
Someone asked if the trailing edge needs to be sharp. Turns out the trailing edge needs to be blunt, not sharp with the exact thickness determine by things like Reynolds number, airfoil, etc. but for us, all that really matters is not sharp. In race cars, they use Gurney flaps to do this, but the race car guys didn't really understand this and started using gurney flaps to increase downforce and it ended up making more drag which they thought was more downforce. If interested, there is a nasa paper out there that talks about blunt edges and the ideal gurney flap height. I think I might still have a copy in my race car archives.. JMHO
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done less baffles and airbox
Fiberglass 95%
Old 04-22-2016, 10:46 PM
Aero_Octaveus Aero_Octaveus is offline
Default Blunt edge is good!?!
A blunt edge is music to my ears. My rudder does not come to a sharp point due to lack of enough countersink on the wedge. I was going to fill the slight gap with 3m 2216 epoxy and sand it smooth. Sounds like I may have failed positive on this one... Woohoo
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2021 Donation Current
http://garetsrv.blogspot.ca/
