First of all let me introduce myself. My name is Aitor, I live in Irving and last January started building an RV-9A. This forum has been an amazing learning resource, and I'm very thankfull for that.
In the last couple of months I've been able to work and finish both the vertical and horizontal stabilizer. As many people before me, I had to re-order a couple of parts to replace, and reassemble with results that I feel are decent. This bring me to the question, How can I be sure that what I'm doing is right?.
Let me explain. I took the fundamentals class at Synergy Air and learned a lot. Using that knowleadge plus my previous experience restoring cars, assembling engines, compressors, pumps and the like I've been able to get through the build. I can read the plans and pretty confidently know what to do and when. The problem I have is that I keep doubting myself. I do not have a way to compare my job to what it is good, and what is not. The last rivets I set in my horizontal were the ones between HS905, HS904, doubler, front spar and the shim. In general they are OK, a couple I feel should be better, but I do not feel capable of replacing them.
This last part is what made me write this post. Am I overthinking?. Should I just wait and look back at things that I may not like and re-do them later?. I simply should just let go and stick to cars or things that I know?.
Any piece of advice would be really appreciated.
Regards,
Aitor
P.D: I've been writing a little bit of my build here: http://aitor11.com
Regards,
Aitor
