When I got my panel from Stein, the temp probe was wired to the panel with about 10 feet of wire run. I read where many probes have been located on the wing at the inboard inspection panel. Do I need to cut the wires and install the probe and run the wires in the wing first, then join them inside the fuselage, or is it possible to run the probe and wires after the wing is installed. I think I know the answer, but just in case......
