Old 02-02-2021, 06:46 PM
rileyspoon rileyspoon is offline
Default Why are they not using the Dynon Radio with Dynon panel?
Noticed that when I ordered my 12iS avionics that even with the Dynon panels the radio was the Garmin GTR200, not the Dynon radio? Anyone know why you don't get the Dynon radio with the Dynon panels? Seems like they would be more fully integrated. With the Garmin radio is it still possible to set frequencies from the panel?
Old 02-02-2021, 07:08 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Integrated just fine. Yep you can pull up frequencies on the Dynon and set the comm frequencies. Works great!
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2021 donation current
Old 02-02-2021, 07:19 PM
Bob Y Bob Y is offline
To each their own, I guess, but yes, the GTR is a nice radio, but I think Iíd also prefer the Dynon. Having ground, tower, ATIS, and approach frequencies at your fingertips certainly reduces workload, especially in towered environments when having to change from approach, to tower to ground with the touch of three buttons while landing without having to do any knob turning. No idea why itís not an option at least.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
Old 02-02-2021, 07:21 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default intercom
The Garmin radio includes a built-in intercom, but the Dynon does not, AFAIK, so there would be the extra cost of an audio panel with the Dynon. So that's possibly why.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 02-02-2021, 08:56 PM
There appears to be space for both, at least in the iS panel., even with the AP knob modules. I’d have still liked to have had the option.
Old 02-03-2021, 12:43 AM
noelf noelf is offline
I don't remember the Dynon com radio being able to tune in VOR or ILS frequencies. Some pilots may want that ability and go another route.
Noel
RV-6A N6NF
tip-up
flying
Old 02-03-2021, 04:17 PM
funflying funflying is offline
Iím with you on this option. When my original SL40 needed to be repaired/just replaced the circuit board I looked into using Dynon Comm or Garmin GTR 200. Since I have a Skyview I believe if the SL40 gives me trouble again I would go to Dynon.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 02-03-2021, 09:07 PM
greghughespdx's Avatar
The Garmin radio works well with both Garmin and Dynon EFIS systems as integrated. The GTR includes a built-in intercom and now Bluetooth, where the Dynon COM doesnít.
And at least as important as the above points, the fewer components we pre-build wiring harnesses for and standardize on (itís an LSA after all) the less it costs for us to produce the aircraft kit for you. Dynon and Garmin donít communicate using a common network buss, so it really is quite complex to support both. The overhead (and therefore cost) associated with the wiring harnesses options that already exist is pretty significant. These multiply when we start adding more and more radios etc without wiring basics in common.
Greg
Greg Hughes - Van's Aircraft - Director - Community, Media, Marketing, Support
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 02-03-2021, 09:30 PM
jliltd jliltd is offline
Having flown both, and troubleshooted the Dynon, I vastly prefer the GTR 200B. Perhaps things have changed in the last 18 months but the Dynon com was really flakey two years ago and Dynon had a bunch of band-aides like notch filters and other things to try to get their com to play well. I have never had to make a hobby out of communications since running a MGL V10 (which is the worst). I just want a radio to work without thinking about it. I have never had trouble with a GTR.
RV-8
(a few more airplanes too)
Old 02-04-2021, 06:43 AM
airguy's Avatar
airguy airguy is offline
Dynon's strength is in the EFIS side of things, not radios. I'm a Dynon guy for all their stuff except the COM radio. It works, but it's not quite top-shelf.
Garden City, TX VAF 2021 dues paid
N16GN flying 750 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440
