Old 04-04-2021, 02:26 PM
cderk's Avatar
cderk cderk is offline
Default Window Tint?
Was wondering if anyone has come up with a good solution for blocking the scorching heat from the sun while flying their 10? I was looking at www.justplanetint.com - they have a $50 stick on piece as well as a $20 “slap shade”. Anyone using these?
Charlie
Old 04-05-2021, 05:21 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
My wife and I use the plastic stick on film that I purchase at Walmart. I cut three pieces. One piece goes entirely across the windscreen and covers the top 1/3 that I use for cruising south, another piece matches the entire side window, and a third is a 1 foot square for misc. positioning. The film uses static to cling to the window. It's cheap and comes in two shade of tint. I use the max tint.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 04-05-2021, 06:21 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Charlie
I use one of these and move to where sun is brightest. (might get two) Works well. https://www.aircraftspruce.com/catal...ot11-13316.php
Randy Vanstory
Flying RV10 - N783V
1st Flight 08/20/2020
Donation Happily Made 2021
Old 04-05-2021, 06:28 AM
rvdave rvdave is offline
Amazon has groups of 2 or 4 suction cup shades.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I also purchased a single one at Oshkosh a couple years ago from Rosen I think it was for $50, that works well also.
I bought the perimeter cling type that also work but the plastic will lose its shape if you don’t keep it flat, then won’t adhere correctly.
Dave Ford
Cadillac, Mi
Old 04-10-2021, 10:28 PM
UAL Driver UAL Driver is offline
The Best I've seen are the "Kinder Fluff", also at amazon. Stick great and have two levels of blockage. They simply work much better than Boeing designs.
Old 04-19-2021, 09:44 AM
iwannarv iwannarv is offline
On the topic of tint, I plan Cee Bailey's windows/windshield in the Solar Gray tint. While its very close to Van's standard, has anybody inquired if they can produce just a shade darker? Nothing extreme to hinder night visibility, but something that is a little closer to automotive legal tint levels.
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Building, Finish Kit - May '21
Never judge a man by his trim tabs.
Old 04-19-2021, 10:42 AM
lr172 lr172 is offline
I bought a roll of the Gila window tint material (removable / 20% VLT) and installed on both the rear windows. Works well, but the optical clarity is not good enough for the front windows. Because of the curvature, I have a couple of small air bubbles that I couldn't get out. Helps for the passengers.
Larry
Old 04-19-2021, 11:51 AM
cderk's Avatar
Thanks Guys - ordered the Kinder versions. Larry, I did consider the Gila tint. A fellow RV10 builder installed it and it looks great. I agree though on the clarity. Unfortunately the non-adhesive stuff isnt as clear - but its the only one compatible with our plexiglass windows.
Old 04-22-2021, 09:13 AM
greghale greghale is offline
I bought a set of Aero-Shields shades for my rv10. They are custom cut for each window with suction cup attachment. A little expensive $250, but work perfectly cutting down the sun in flight.
https://store.aero-shields.com/catal...cf54c46d195440
Greg...
RV8 - Sold
RV10 - N210KH slow build / flying
www.nwacaptain.com
KRVS - Tulsa
dues paid for 2021
800 hours and counting....
Old 04-29-2021, 05:53 AM
MarkStringfellow's Avatar
MarkStringfellow MarkStringfellow is offline
Just ordered a complete set of Cee Bailey's RV10 windows and was wondering that as well. I use the Gila tint on a Diamond DA40 that I fly and it works well enough. Optical clarity is poor though. Plus is that you cut it any shape you want.
