  #11
Old 01-17-2022, 11:01 AM
Duhg Duhg is offline
Thank you Phillip, this is exactly what I was looking for. It looks like you added the holes for the right side conduit under the floor to mirror the existing ones on the left?
Fastback 8
Fuselage in progress
Old 01-17-2022, 07:13 PM
N546RV's Avatar
N546RV N546RV is offline
Yup, I put in conduit runs on both sides. I know I had to make holes on one side, though I don't recall specifically that it was the right, and I'm not finding the relevant build log entry off the bat.
The right side is my main wiring route, and honestly it's so full that I'm skeptical that I'd ever pull any additional wires through for retrofit work later on. The left side is mainly there "just in case," but at the moment it does house a coax run from the ADS-B receiver on the rear avionics shelf to the antenna mounted just in front of the rear seat.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
