Originally Posted by markduffield
I bought an RV-8 with leading edge lights installed. They are so anemic as to be useless and until I get them replaced I will not be flying at night. They are not even bright enough to taxi the aircraft safety. I'm looking for a recommendation of something that actually works so that I can open up the other half of the 24-hour flying window. Brighter is better so long as it stays within the 5 amp breaker limit. I would prefer a drop-in solution if one is available. pic of current light is attached. Thanks for the help
Question - do you know what size the power wire is going out to your wing landing lights? A 5 amp CB will protect a 22 awg wire, even considering the length of the round trip to your wing tip. I’ve never heard of anyone using a 22awg wire to power their landing lights. Should be more like 18 awg or more, which would be protected by a 10 amp CB/fuse, as Paul (FlyLeds) mentioned for his bright landing lights. If you have a fatter wire in your wing than 22 awg, just trade that 5 amp CB for a larger one and upgrade your lights.
