  #21
Old 12-24-2021, 10:29 AM
Bavafa Bavafa is offline
Originally Posted by Kyle Boatright View Post
Sounds like you're talking about elevators, not ailerons? There is no place to add external weight on ailerons.
But, to the OP. I would check the trailing edge radius and straightness (a strait edge running chordwise should lay straight until it goes off the aft edge of the aileron. It shouldn't encounter a "speedbump" of metal at the TE). If that is OK, then I'd look at removing the paint and repainting with a non-insane amount of paint.
Oh yes, you are correct and I am sorry for the incorrect post here. I should have had my coffee first.
My comments are about the elevators.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 12-25-2021, 01:09 PM
Scotty G's Avatar
Scotty G Scotty G is offline
I appreciate all the effort people made in the replies. Thank you.
I have a hard time believing the paint shop somehow crimped the trailing edges or otherwise deformed them.
The *only change* by my eye is the paint addition. I watched them spray the wing. It’s a hideous amount of paint. (I’ll be more than happy to warn you away from this shop privately.)
Rigging didn’t change.
At any rate, I’m suing the paint shop for breach of contract, and the owner became violent with me right off the bat - so simply getting the ailerons repainted there (or any correction work for that matter) is not an available avenue.
Scotty G
CHD
Old 04-21-2022, 04:52 PM
Esmokeshop Esmokeshop is offline
dosent imbalance in ailerons create flutter...
