The old adage of RTFI springs to mind.
We are getting close and enjoyed this today.
http://www.youtube.com/watch?v=6lkJfrD_y_c
Stunned that it started so quick, it has been on the airframe for 3 years, pickled. Went through a standard de pickling process with pre oiling etc.
Problem was it ran OK, but only on one P-Mag. It was the one firing the top auto plugs, the left P-Mag was dead as a dead thing.
Head scratching, multimeter out, all OK, power through, P leads checked, no spark.
Re timed....... hang on, why does the right P-Mag time OK and the left one stay green as you turn the engine.
RTFI.
The engine arrived from Mattituck with Slicks and LASAR which we removed in favour of P-Mags due to lack of support from Unison and less weight.
On page 9, it quite clearly says to ensure if you had impulse on the left mag, to remove the spacer collar........ Buttocks !
The left P-Mag was not engaged in the drive gear, it was stationary.
20 minutes of hacking, chewing, swearing, knuckle baring and 'adapter' making as the stud was locktite'd into the case, we tried again.
Oh - Yesssssssss !
We have a running engine.
Plenum seems to be working fine, all temps even and stable, oil pressure rather high - 95psi but I am on Shell 100 straight, so we will see how it drops when I run it for more than 5 mins and it warms through.
Need to get cracking with the paint now and hopefully 'that grin' will appear before the summer.
RTFI.
Oh - Yesssssssss !
