  #11
Old 10-13-2021, 01:29 PM
MartySantic's Avatar
MartySantic MartySantic is offline
Smile Good solution!
I shortened the spring 1/2" in accordance with the Notification. Makes a world of difference. I had to remove the 4 screws holding the flap detent bracket down (Thank you, Scott McD) to get enough clearance the remove the button/rod and spring. Cut the spring with the Dremel and small cutoff wheel.
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 10-13-2021, 11:33 PM
dbhill916's Avatar
dbhill916 dbhill916 is offline
In case anyone else ever wants to alleviate the possibility of getting pinched, the button part was redesigned many years ago to do away with the gap that causes the pinch point and it it very inexpensive to buy.
Scott, do you have a part number on hand?
-dbh
David B. Hill
N76012
RV-12 #0760
Dues paid through 6-2022
Old 10-14-2021, 01:07 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
VA-110 Flap Knob
Click image for larger version
Name:	Screen Shot 2021-10-14 at 3.05.37 AM.png
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 735
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 10-14-2021, 08:15 AM
rvbuilder2002's Avatar
-dbh
I am pretty sure the profile of the part got redesigned but the part # was left the same.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
