Old 07-20-2019, 02:51 PM
jor.ezq jor.ezq is offline
Default Rv 10 aileron trim spring noise
Hi everyone !
I hate that noise when you move the aileron or the stick in ground.
Did anyone solve this ? Or maybe I have a construction issue ?
Thanks folks !
Rv 10
80 flying hours
Buenos Aires
Argentina
Old 07-20-2019, 03:33 PM
Default ALSO...
If you are using a garmin system, it has auto trim capability.
This requires that the servo drive wires are connected to the roll servo (2 wires).
The default location for the aileron trim is in the LEFT wing but the roll servo is in the right.
If you mount the aileron trim in the RIGHT wing, it simplifies running the wires to the roll servo for the auto trim function.
Mounting the aileron trim in the LEFT wing and using auto trim, you will need to run those wires from the LEFT wing trim servo to the RIGHT wing roll servo.
Just something to consider...
Bob
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
Old 08-03-2019, 11:34 AM
ClarkieSr ClarkieSr is offline
Originally Posted by johngoodman View Post
Rob,
Wiring for aileron trim is the least of the problems. The trim motor mounts on the Inspection Plate door closest to the fuselage. It uses two rather large springs that are attached to the Aileron Push Tube about a foot from the motor on both sides. The only way I know to install it, after the wing is attached, is to take the wing back off. You have to put two attachment points for the springs on the Push Tube, which means pulling the Push Tube.
In short, make up your mind before you attach the wing.
John
You do not have to remove the wings. Disconnect the both ends of the push road, remove the wing tip fairing and slide the rod out the end of the wing. A lot less work and time involved
Old 08-05-2019, 05:57 AM
Dustyone Dustyone is offline
Default URGENT :NO NOISE PLEASE
"Hi everyone !
Thanks folks !"
I have now found 3 x RV-10's that have had the Aileron Trim springs rubbing on the Aileron pushrod tubes. The plans were changed to require the builder to inspect and confirm that there is no contact in 2016, however prior to that I guess builders just kept building.
The fix is simply to bend the Aileron Trim Motor arm ,forward, away from the Aileron pushrod approx 3/16".
If you have any noise, please inspect, as the springs will eventually wear through the pushrod with possible dire control issues !!
Photos from a 1000hr + RV-10,
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
VH-XTE 900hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 11-04-2019, 04:39 PM
Default aileron trim spring noise
Originally Posted by Dustyone View Post
"Hi everyone !
Thanks folks !"
Thank you Ashley, very useful data !!
Old 11-04-2019, 09:42 PM
TimO TimO is offline
I've seen the same on another RV-10 before, as well. They replaced the pushrods. Definitely inspect and listen for any scraping.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
Old 11-05-2019, 09:26 AM
Kenny Gene Kenny Gene is offline
Default Rv10 aileron trim
Guys,
I never liked the Rv10 aileron spring trim, so I took mine out and off completely. The plans trim system did not appear to be effective to me on my 10 in the air and additionally I didn't like the spring applying pressure to the stick or my leg after landing and taxiing. I purchased the 1" servo drive from Ray Allen, removed my left aileron, installed servo, attached trailing hinged trim tab (about 7" piano hinge) with horn/push rod to the Ray Allen motor installed in aileron. I love it.
I don't know how to post pictures, but I can send pictures if anyone would like to see a few. Send me a PM with your "regular" email address.
Kenny Gene
Wichita KS area aviator
Rv7a AWC 09-07 690 hours sold 11-11
Rv10 AWC 10-10 847 hours
Old 11-06-2019, 05:08 AM
ADub ADub is offline
Rob, if you want more details the installation instructions are on the thumb drive from Vans - OP-38. The springs connect to the aileron control tube 6" inboard and 6" outboard from the trim servo arm.
Old 11-07-2019, 11:06 AM
rongawer rongawer is offline
As a "belt & suspenders" option, I put some UHMW tape along the push-rod tube to provide some rub protection just in case the spring were to contact the tube.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 11-08-2019, 06:58 PM
rvanstory's Avatar
rvanstory rvanstory is offline
Bob, in process of wiring roll A/P and trim motors now. Can you direct me to Garmin information regarding which 2 wires to run over to right wing and how to tie them in? I already have trim motor in left wing, so will need to run the 2 wires over to right wing.
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020 / Current Hrs - 279
Donation Happily Made 2022
