How did you guys route you coax cable to your TPX and comm antenna? I have both mine going down the center trunk. The comm antenna is just behind the gear and the txp is back about the rear pax seat area. I'm getting static on the radio which I suspect is partly from the cables being close together.
How close is too close?
I've never like electricity since I stuck a bobby pin in the wall socket as a child.
Skip
RV-4 #1904
Skip
RV-4 #1904
