VAF on Twitter:
@VansAirForceNet
  #421
Old 07-31-2022, 08:18 PM
Dirt911 Dirt911 is offline
Originally Posted by PaulvS View Post
Conversely, why does the RV-15 need 215 hp, versus C170 that has 145 hp? Is it because the RV-15 airframe is HEAVY?
If I could put the 390 on my 170, I, and most 170 owners, would.
Old 07-31-2022, 08:19 PM
greghughespdx's Avatar
Nope. The 170 weight and the target weight for the kit RV-15 are essentially the same. We just want to do more.
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 07-31-2022, 08:53 PM
scsmith scsmith is offline
Ask anyone with a C170. One of the few shortcomings it has is that it is woefully underpowered. The O-360 STC helps a ton. the IO-390 would be even better!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
Old 07-31-2022, 09:46 PM
BHunt BHunt is offline
Originally Posted by terrye View Post
Er...you know Vans announced the RV-16 last year as a 4 seat high wing bush capable airplane? Considering the IO-390 from the RV-14 is the actual engine used in the RV-15, I expect an IO-540 from an RV-10 will be the actual engine used in the RV-16.
Ummm…. Do you have info on this? Because I don’t think this is accurate at all.
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 07-31-2022, 10:00 PM
Definitely not accurate. Not even true.
Old 07-31-2022, 10:32 PM
john kelley john kelley is offline
The only hint I heard at one of the OSH forums was that this would not be the last VAN's high wing. Read into that what you will.
John Kelley
Palatine Il
RV-8
Old 07-31-2022, 10:40 PM
Thebert Thebert is offline
I’d imagine the engineering work going into your first high wing when you have only built low wing aircraft to this point is more substantial than your second or 3rd high wing aircraft so I’d be shocked if this is the last high wing. That said I could see a RV 14 high wing size before a Cessna 180/185 size
Old 08-01-2022, 01:15 PM
PilotjohnS PilotjohnS is offline
Default joking
" oh i wish I was a Vans,
that is what i truly want to be,
because if i was a Vans,
everyone would be in love with me."
Cessna 172
John S
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
Old 08-01-2022, 01:45 PM
Is your 172's name "Oscar?"
Dave
Old 08-01-2022, 03:16 PM
bnt83 bnt83 is offline
Originally Posted by gasman View Post
Yes, this is a nice seating position. Kinda like sitting in a dining room chair.
Attachment 28358
Look how nice it would be to work on the brakes.
BIG DRAWBACK..... fueling.
note......I would add a fold down arm rest on the side of the seat. Also, those seats would make great campsite seating.
I'm a weird hybrid with amputations on both feet, I hate low winged stuff I gotta crawl onto to get in & out of, its twice as much work as refueling a high wing. I may load and unload 4 times about every tank of gas. If my feet are worn out for the day, or its bitter cold winter weather etc, I'll gladly land somewhere with an open FBO that refuels it for me.
