mill2978
In my RV8 the throttle lever has 90% of it's action in the first 30% of travel, the remaining 70% is only 10% of the action. This makes small power changes challanging, esp at the lower end. How can I adjust the throttle cable rod ends to make the action more evenly spread out across the range of motion of the lever? The rod ends are currently +/- 1 thread difference. Do I shorten the lever end and lengthen the throtle end or vice versa, is there a different adjustment I can make?
