Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
09-06-2018, 09:29 AM
Originally Posted by Robb
I guess this is what you have to deal with on experimental airplanes.
No, you don't. Quite the opposite. With an experimental we are free to make whatever changes we wish to improve cooling performance. Of course, the two-edged sword rule applies; we're equally free to make bad choices.
Dan Horton
RV-8 SS
Barrett IO-390
10-14-2018, 11:52 PM
I finished the baffle modifications for cylinders 2 & 3 (quite similar to the pic that BillL posted) and am extremely happy with the results. No. 2 (the hottest) dropped about 25 degrees and is now the coolest! No. 3 is down about 10 degrees. Shoulda done this sooner.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
10-15-2018, 06:37 AM
Just finished the #2 cylinder mod as presented by Bill and also having completed the widely accepted modification duct on #4. Glad to hear your results were acceptable Doug. Confident I have avoided a potential overheating problem. Would never have know about these proven solutions if not for the ?VAF? Thank you gentelmen.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP. KJNX
10-30-2018, 12:46 PM
Does anyone have any pictures of successful baffling improvements for cylinder #4? I've seen lot's of great ideas for #2 and #3. Thanks!
IO-360 parallel valve, Van's baffling with stock oil cooler.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1480 Hours
06-18-2019, 01:51 PM
I know this thread has been extensively discussed last fall, but I have a different question. Our RV14A IO390 runs cold. Typically front cylinders 1and 2 low 200’s CHT’s, rear’s 3 and 4 mid to upper 200’s. This is at cruise. Almost never see 300 CHT’s. The CHT input curves were switched in our G3X from K to J or vice versa (can’t remember) then the CHT’s look normal. The ones with the cold numbers were the correct for our installation.
Any input appreciated.
06-19-2019, 12:31 PM
Highly suspect in my opinion. Type K thermocouple wire must not be mixed with Type J. The correct wire must be used with the correct probe, then configured properly in the G3X. Wire color is the easy way to tell which you have. Read this builders note from SteinAir:
http://www.steinair.com/wp-content/u...uple-cable.pdf
Wire:
https://www.steinair.com/product-cat.../thermocouple/
Also, I recently learned there are some grounded and ungrounded CHT probes. If I remember correctly, Advanced Flight Systems used ungrounded Type J CHT probes. Those WILL NOT work with a G3X. I had to change out 4 probes on a recent build to Grounded Type J (so I could use all my existing wiring behind the panel) and that corrected the false indication.
Low 200's at any power setting other than idle, in the winter, doesn't seem possible.
Lancair Super Legacy
Laminar Consulting LLC
03-18-2020, 06:40 PM
BA
Originally Posted by N942R
On those I have mounted the oil coolers on a NACA duct on the "Right side" of the cowl which will solve that problem.. Nothing wrong with the coolers... But that is a separate issue.
Submerged NACA ducts are problematic for an oil cooler, many test, experience, articles has shown this success is not automatic with a NACA scoop. Love to see your whole NACA oil cooler set up.
1) NACA - you can also cause overheating by pressurizing the lower cowl with your NACA scoop if the oil cooler is dumping air back inside the lower cowl.
2) NACA can flow volume when there is little to no resistance and lower pressure at discharge. Dave Anders wrote an article in Kit plane (Oct 2018 Optimizing Induction Air Fine-tuning intake system runners for increased performance and economy. Speed with Economy, Kent Paser wrote about NACA scoops more enthusiastically in his classic book. However they are not magic and often implemented, located and used incorrectly. They always look "cool" but they are no free lunch. They do add drag and may produce very little airflow unless you do everything correctly. You might be better off with an external scoop and take the drag and get real RAM Pressure, with a discharge separate from lower cowl plenum. Many planes like the DC-3 has the oil cowl completely outside the cowl. The cooler needs high delta P to flow air and NACA scoops don't create pressure but flow air, at lower pressure head. Add back pressure on the exit side of the cooler inside cowl you may end up with no flow or reverse flow.
http://www.vansairforce.com/communit...ead.php?t=5551
http://www.vansairforce.com/communit...ad.php?t=97016
Car guys also debate the Scoop vs (submerged) NACA
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2023 Donation Made!
08-15-2022, 09:05 PM
Do I have Recovery? Pressure Recovery.....
After a lot of hours, I'm taking a new look at my cowl and engine cooling. I had stock baffles for the first few years, then I made a bad plenum that has worked fine for many hours, but I never knew if it worked well. I know the seal at the inlets was not great and the FAB to cowl seal was not great either, but I know both can be improved...... My only real complaint is full power ROP climbs get the back two cylinders to 425 quickly before I pull back(on the rare occasion that I do it)
Following the teachings of Professor Horton, I made piccolo tubes and found a cheap used digital manometer - then I got some data tonight, allowing me to ask the question:
"Do I have recovery" What say you cowl doctors? The cowl needs some rework after 2600 hours, so maybe this winter I cut some fiberglass.....
Here is the cockpit setup running in diff pressure mode. I took some data comparing the upper and lower to ambient cockpit pressure, and the diff was same as the diff pressure on the screen.
Here is the data and a graph (all data @ 3000ft)
Pete
Amateur Plane - RV-9A N789PH - 2650+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
08-15-2022, 09:59 PM
Originally Posted by petehowell
"Do I have recovery" Here is the cockpit setup running in diff pressure mode. I took some data comparing the upper and lower to ambient cockpit pressure, and the diff was same as the diff pressure on the screen.
Hi Pete. Yes, you have recovery. The question is how much, specifically the percentage of available dynamic pressure converted to upper plenum static pressure. DeltaP across the baffles doesn't help us; we need upper plenum deltaP vs freestream static. I tap the aircraft static system for freestream static.
So, easy as 1-2-3...
1. List upper plenum static vs freestream static deltaP for each airspeed.
2. Compute available freestream dynamic pressure for each airspeed and convert it to inches of water.
(There is an excellent online calculator here: http://www.aerospaceweb.org/design/scripts/atmosphere/ Don't neglect the temperature correction, plus or minus standard day temperature for that altitude. 25C would be a +14 above standard for 3000 ft.)
3. Divide upper plenum static by freestream dynamic. Good systems are generally above 0.8.
It's very hard to fly a specific true airspeed, for example, exactly 150 KTAS. It's a lot easier and more accurate to fly a NTPS 3-leg while collecting the pressure information. That way you have an exact airspeed for each data point, thus a precise dynamic pressure.
Illustration below from NASA CR3405.
Dan Horton
RV-8 SS
Barrett IO-390
08-15-2022, 10:25 PM
More data
**** - I have to fly again..... Thanks for the input, I'll tap the static and get the data!
Pete
St. Paul, MN
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
