Keep VAF
Going
10-25-2020, 10:25 AM
construction space minimums
Hello all: I am thinking of trying to build in my basement (I don't have a garage) and wondering about getting things in. The largest opening would be through a window that is 48x52 inches, and I am looking at the RV-14 QuickBuild. I know the crate dimension exceeds the window opening but I would presume the individual components, once uncrated, might fit one at a time. Also wondering about getting things back out again once completed!
Thanks for any info on this.
David Brody
10-25-2020, 10:36 AM
Big door
SB parts will go through no problem. You may have to curl a skin. I doubt finished wings or fuse will come out. My 7 wings are about 4' wide plus the depth of the chord would make for a tight fit. 7 fuse is at least 4' wide and about the same tall. 14 is bigger. QB parts are basically finished dimension.
Buy a chainsaw!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
10-25-2020, 11:03 AM
David Brody
I can't find the chord of the -14 wing. Anyone? Bueller?
Your window opening is about 5'8" on the diagonal. I'm guessing the wing WILL fit through it with the flaps and ailerons removed. Worst case, maybe you leave the bottom skins and the flap/aileron hinges off, exit the nearly finished wings through the window and finish the wing(s) elsewhere.
Fuselage? I don't think there's a chance.
Compared to the cost of the project, having a larger opening cut into the basement isn't frighteningly expensive. I turned a 36" basement door into a double door (72") to get the -10 out of the basement. That was through a brick wall... Cost ~$2K, including $1K for the custom door and another $1K for the brick mason crew. I did the framing and door tear/out/installation.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
10-25-2020, 11:53 AM
Since there is no wing taper, just divide the area (126.1 per Van's website) by the span (27) and get 4.67 ft or 4'8". A bit smaller than the 4'10" chord of the 7/8 wing.
10-25-2020, 02:26 PM
follow up construction minimums
Thanks to all. I'm thinking then that trying to open up the foundation wall would be the most workable solution. Any specifics as to the cross sectional area of the several aircraft components?
David Brody
10-25-2020, 02:49 PM
Would you have room to store other parts of the plane while you're working on something? Or would you make a suitable opening and then build the plane, knowing that your new walk-out door will find other uses.
My own experience is that parts accumulate and shop space is always at a minimum, no matter how much you have.
Dave
10-25-2020, 02:53 PM
unfluencer
As an option, dig/remodel when you're done.
Article and more pics: https://www.pennlive.com/midstate/20...mans_base.html
v/r,dr
PS: Dan and I no relation.
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Typed in the EMB-505 (Phenom 300). Available for contract work. (resume).
- Part time: Supporting Crew Member CAE EMB-505 Level D Sim @ KDFW.
10-25-2020, 05:36 PM
Dave
I think there would be room, though probably a bit tight. But the advantage of working from home would, I think, outweigh any benefit from a larger but off site space. In another life I will have a garage...
10-25-2020, 05:38 PM
Originally Posted by DeltaRomeo
I can see this, and in fact probably the only way to make it work. Great story by the way.
10-25-2020, 06:23 PM
I just measured my 10 wing (same airfoil as the 14) and without the flap or aileron it’s right at 48” including the brackets.
Thread Tools |
Display Modes |
