Old 08-15-2021, 03:49 PM
Bungalow Al's Avatar
Bungalow Al Bungalow Al is offline
Default What thickness Alum for Avionics Shelf between Panel and Subpanel?
Greetings all,
I am starting to lay out my panel avionics and how I am going to mount them. Working with the great folks at SteinAir. I am going to use a hinged drop down shelf for some components.
What I need to determine is what thickness aluminum sheet I should order to create it out of?
Any suggestions....?
TIA
Al "Bungalow" Brownlow
RV14 - N714AL Reserved
At the Hideout
"If we're not having fun, we're not doing it right"
Old 08-15-2021, 05:54 PM
mfleming's Avatar
mfleming mfleming is offline
I think I used 0.32" but I also added a stiffener on the bottom of the skinny ones. The bus tray was stiff enough with the fuse blocks attached.
ID:	14704  Click image for larger version
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 08-15-2021, 06:11 PM
wirejock's Avatar
wirejock wirejock is offline
Default Shelf
I used .032" as well. Two shelves. Each spans from panel to subpanel. Hinged fore and aft so they can swing either way or be removed quickly as well. It's a 7 slider though.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 08-15-2021, 06:20 PM
jliltd jliltd is offline
I bought a piece of honeycomb aluminum panel from McMaster-Carr. Super stiff and light.
https://www.mcmaster.com/catalog/127/3993
Jim Ivey
RV-8
(and a few more airplanes)
Old 08-15-2021, 11:11 PM
rapid_ascent rapid_ascent is offline
I made a shelf for my GDL 52R out of 0.062" with angle stiffeners. That was what I had on hand, but I think something around 0.040" is sufficient.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-16-2021, 05:33 AM
AlexC AlexC is offline
I used 0.063" aluminum to create a tray, but instead of a hinge, I just used 6 nutplates/screws (3 on panel, 3 on subpanel) to hold it in place. Easy to attach and remove.
I installed one tray on each side, since I had a lot of avionics to mount behind the panel. Right side holds the transponder; left side holds the IBBS battery and one of the Garmin LRU boxes.
_Alex
Alex C.
2021 RV-14A: Flying as of 4/13/21 - Phase 1 completed!
1999 Cessna 182S - Sold
https://alex-rv14a.blogspot.com
Old 08-16-2021, 06:22 AM
Thanks, everyone.
I was planning to not use an angle or stiffener and want to be sure that for an ~ 9"x12" sheet that it was strong enough to not bend with the avionics component on it.
Have toyed with both just doing the hinge on the back side (subpanel) and nutplates on the front, or just nutplates all around.
SO the consensus would indicate that say a .040 sheet should be stiff enough?
Back to the ACS website - again........
At the Hideout
Old 08-16-2021, 08:45 AM
Default if...
If you use .032 and put a 90 flange on the long edges, it will be plenty stiff enough...When I did this I used about a 5/16" flange height.
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 08-16-2021, 08:49 AM
jcarne's Avatar
jcarne jcarne is offline
I used 0.32" on my slider. No angle, no bends, plenty stiff enough.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
