Old 03-04-2021, 01:59 PM
bjdecker's Avatar
bjdecker bjdecker is offline
It's a slip fit, you can see the shape in the picture of it on the TCW website.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 03-09-2021, 12:19 PM
wirejock's Avatar
wirejock wirejock is offline
Default Oil cooler butterfly valve
Yep. Fits perfect. Very light. It comes with an adjustable arm.
Here's the BOM for anyone interested.
20006A Oil Cooler (Vans)
VA-186 Mount (Vans)
VA-187 4" Duct (Vans)
4" Scat
TCW BUTTERFLY VALVE 4" DUCT (Aircraft Spruce)
CABLE "B" NUT THROTTLE 222-1 (Aircraft Spruce)
Click image for larger version
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-30-2021, 03:03 PM
Davea320 Davea320 is offline
VA-186 Mount (Vans)
4" Scat
Larry
Is that the setup for the larger oil cooler for the larger engines? Iím trying to get the right BOM for my standard 7 row oil cooler since I live in a cooler climate. ACS has a kit with 3Ē ductwork that looks like it should work for me, but wanted to check here for opinions.
Dave
RV7 QB started 1/17
Working on Baffles and plenum
2021 dues sent
Old 04-30-2021, 03:40 PM
bjdecker's Avatar
Originally Posted by Davea320 View Post
Larry
Dave
What engine are you planning on?
Brian Decker
1986 Mooney 205SE
1980 Mooney 231
Old 05-03-2021, 06:47 PM
Default Oil cooler
I have an IO-360M1B from Vanís/lycoming 180 hp
RV7 QB started 1/17
2021 dues sent
Old 05-04-2021, 07:56 AM
bjdecker's Avatar
You'll be fine with a SW8406R fed by a 3" to 4" duct.
The M1B doesn't have piston oil squirts so it doesn't put a ton of heat into the oil like the A1B6 does.
Brian Decker
1986 Mooney 205SE
1980 Mooney 231
Old 05-04-2021, 05:52 PM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
VA-186 Mount (Vans)
4" Scat
Attachment 9192
Larry,
Do you think the butterfly valve could be trimmed down on the forward side where it meets the Vans flange? If I install that as you have it laid out in your photo, I'll have to redirect my scat hose forward and it seems like it would be better if I could shorten the valve housing.
Rob K
RV-8 N884RA under construction
Old 05-05-2021, 10:32 AM
Ralph Inkster Ralph Inkster is offline
You could trim it a bit but be mindful that the butterfly valve blade doesn't hang up on the flange.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
