Old 02-26-2021, 01:19 PM
Kupde Kupde is offline
Thought I would thank folks who had commented on this one. I found the smoking gun which was small chafe in the insulation between the 2 thermocouple wires. The red wire wore through where it was rubbing against the opposing wire nut. I guess best practice would be to insulate all the T/c connections before attaching the final sleeve. Iíve tried to attach a picture but not sure how well the attachment will come through.
Kevin
Old 02-26-2021, 01:46 PM
bjdecker's Avatar
bjdecker bjdecker is online now
I would place the lock washer under the nut. It looks like the washer is under the screw head...
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 02-26-2021, 03:41 PM
jakej jakej is offline
A star washer should be fitted between the ring terminals as a first course of action as per instructions for this type of connection.
